| | setting the association in control panel hey, a family member send me an e-mail with an attachment but when i try to open it to view it it comes an error message of, THIS FILE DOES NOT HAVE A PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS ACTION. CREATE AN ASSOCIATION IN THE SET ASSOCIATIONS CONTROL PANEL. My question is how I do that? |
| | Re: setting the association in control panel Courtesy of Vista User: Go to help and type "file association" Change the program that opens a type of file If you double-click a file in Windows and it opens in the wrong software program, follow these steps to choose the program you would prefer that file use. You can change this setting for an individual file, or you can tell Windows to open all files of that same type in the software program you choose. 1.. Open the folder that contains the file you want to change. 2.. Right-click the file that you want to change, and then, depending on the type of file, either click Open With or point to Open With and then click Choose Default Program. 3.. Click the program that you want to use to open this file. 4.. Do one of the following: a.. If you want all files of that type to open in the same software program, select the Always use the selected program to open this kind of file check box, and then click OK. b.. If you want only that file to open in the software program this one time, clear the Always use the selected program to open this kind of file check box, and then click OK. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Alex" <Alex@xxxxxx> wrote in message news:614AD25A-8321-437C-9A00-44DAF812F903@xxxxxx Quote: > hey, a family member send me an e-mail with an attachment but when i try > to > open it to view it it comes an error message of, THIS FILE DOES NOT HAVE > A > PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS ACTION. CREATE AN > ASSOCIATION > IN THE SET ASSOCIATIONS CONTROL PANEL. My question is how I do that? |
| | Re: setting the association in control panel If you don't have an association for a particular file you likely do not have what you need to open the file. You either need the same program on your computer, used to create the file, or you need an alternative that can handle that particular file association. Just associating any program with a file is not going to do you any good at all. So, maybe if you told us the file extension we could assist you in locating the program you need to open the file. -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) "Alex" <Alex@xxxxxx> wrote in message news:614AD25A-8321-437C-9A00-44DAF812F903@xxxxxx Quote: > hey, a family member send me an e-mail with an attachment but when i try > to > open it to view it it comes an error message of, THIS FILE DOES NOT HAVE > A > PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS ACTION. CREATE AN > ASSOCIATION > IN THE SET ASSOCIATIONS CONTROL PANEL. My question is how I do that? |
| | Re: setting the association in control panel thank you now it works thanks a lot. "Andre Da Costa[ActiveWin]" wrote: Quote: > Courtesy of Vista User: > Go to help and type "file association" > > Change the program that opens a type of file > > If you double-click a file in Windows and it opens in the wrong software > program, follow these steps to choose the program you would prefer that file > use. You can change this setting for an individual file, or you can tell > Windows to open all files of that same type in the software program you > choose. > > 1.. Open the folder that contains the file you want to change. > > 2.. Right-click the file that you want to change, and then, depending on > the type of file, either click Open With or point to Open With and then > click Choose Default Program. > > 3.. Click the program that you want to use to open this file. > > 4.. Do one of the following: > > a.. If you want all files of that type to open in the same software > program, select the Always use the selected program to open this kind of > file check box, and then click OK. > > b.. If you want only that file to open in the software program this one > time, clear the Always use the selected program to open this kind of file > check box, and then click OK. > -- > Andre > Blog: http://adacosta.spaces.live.com > My Vista Quickstart Guide: > http://adacosta.spaces.live.com/blog...3DB!9709.entry > "Alex" <Alex@xxxxxx> wrote in message > news:614AD25A-8321-437C-9A00-44DAF812F903@xxxxxx Quote: > > hey, a family member send me an e-mail with an attachment but when i try > > to > > open it to view it it comes an error message of, THIS FILE DOES NOT HAVE > > A > > PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS ACTION. CREATE AN > > ASSOCIATION > > IN THE SET ASSOCIATIONS CONTROL PANEL. My question is how I do that? > > |
| | Re: setting the association in control panel "Richard Urban" wrote: Quote: > If you don't have an association for a particular file you likely do not > have what you need to open the file. You either need the same program on > your computer, used to create the file, or you need an alternative that can > handle that particular file association. Just associating any program with a > file is not going to do you any good at all. > > So, maybe if you told us the file extension we could assist you in locating > the program you need to open the file. > > -- > > Regards, > > Richard Urban > Microsoft MVP Windows Shell/User > (For email, remove the obvious from my address) > > > > "Alex" <Alex@xxxxxx> wrote in message > news:614AD25A-8321-437C-9A00-44DAF812F903@xxxxxx Quote: > > hey, a family member send me an e-mail with an attachment but when i try > > to > > open it to view it it comes an error message of, THIS FILE DOES NOT HAVE > > A > > PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS ACTION. CREATE AN > > ASSOCIATION > > IN THE SET ASSOCIATIONS CONTROL PANEL. My question is how I do that? > The above method doesn't work for my Home Premium. I am trying to open a WordPerfect (.wpd extension) attachment to a Windows Mail message. MS Word does open such files if they have been saved form the e-mail message but that is cumbersome. In XP doubleclicking the attachment opened .wpd files in Word, which is what I want to do now. jack1961 |
| | #6 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: setting the association in control panel Take a look at these two tutorials for help on this. Default Programs Default Programs - Program Default Associations Shawn |
| | #7 (permalink) |
| | RE: setting the association in control panel "Alex" wrote: Quote: > hey, a family member send me an e-mail with an attachment but when i try to > open it to view it it comes an error message of, THIS FILE DOES NOT HAVE A > PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS ACTION. CREATE AN ASSOCIATION > IN THE SET ASSOCIATIONS CONTROL PANEL. My question is how I do that? |
| | #8 (permalink) |
| | #9 (permalink) |
| | Re: setting the association in control panel DL the file, R-Click it, and then use Open With to associate the file with a program. Buddha "John Redmond" <John Redmond@xxxxxx> wrote in message news:C86EA6E3-BDC5-4478-82E5-BA3909B7BF19@xxxxxx Quote: > > > "Alex" wrote: > Quote: >> hey, a family member send me an e-mail with an attachment but when i try >> to >> open it to view it it comes an error message of, THIS FILE DOES NOT HAVE >> A >> PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS ACTION. CREATE AN >> ASSOCIATION >> IN THE SET ASSOCIATIONS CONTROL PANEL. My question is how I do that? |
| | #10 (permalink) |
| | Re: setting the association in control panel Which file type are you trying to open? See the tutorial here: Error "This file does not have a program associated with it for performing this action" opening email attachments - The Winhelponline Blog: http://www.winhelponline.com/blog/er...iated-with-it/ -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] The Winhelponline Blog: http://www.winhelponline.com/blog Windows® Troubleshooting: http://www.winhelponline.com "John Redmond" <John Redmond@xxxxxx> wrote in message news:C86EA6E3-BDC5-4478-82E5-BA3909B7BF19@xxxxxx "Alex" wrote: Quote: > hey, a family member send me an e-mail with an attachment but when i try to > open it to view it it comes an error message of, THIS FILE DOES NOT HAVE A > PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS ACTION. CREATE AN ASSOCIATION > IN THE SET ASSOCIATIONS CONTROL PANEL. My question is how I do that? |
| how to create an association in set association control panel | Vista mail | |||
| set association control panel | Vista hardware & devices | |||
| setting association control panel | Vista mail | |||
| Help!! - set association control panel | Vista performance & maintenance | |||
| set association control panel | Vista General | |||
