power saving settings
  1. #1
    scrooge's Avatar
    home premium vista (64bit)
    Local Time: 09:22 PM
    hi
    anyone no how to disable the power saving settings ?
    i'm running vista 64bit h/p
    thanks mike
  2. #2
    Andre Da Costa[ActiveWin] Guest
    Re: power saving settings
    1. Click Start, All Programs, and then right click on "Command Prompt".
    2. From the context menu click on "Run as administrator".
    3. If User Account Control prompts you to allow the action, click on
    Continue.
    4. In the command prompt window, type "powercfg -h off" (or "on" without the
    quotes) followed by Enter button.
    4. Close the Command Prompt
    Andre
    Blog: http://adacosta.spaces.live.com
    My Vista Quickstart Guide:
    http://adacosta.spaces.live.com/blog...3DB!9709.entry
    "scrooge" <scrooge.2ypp10@xxxxxx-mx.forums.net> wrote in message
    news:scrooge.2ypp10@xxxxxx-mx.forums.net...
    > hi
    > thanks mike
    > scrooge
  3. #3
    Kristan M. Kenney [MVP] Guest
    For future reference, this only disables hibernation. To disable all power
    saving features, one should switch to the "High performance" power plan or
    customize it further if they so choose.
    Regards,
    Kristan M. Kenney
    Microsoft MVP [Windows - Shell/User]
    > Continue.
    > Andre
    > > hi
    > > thanks mike
    > > scrooge
  4. #4
    RE: power saving settings
    To disable all power saving features, click on the Power icon in your
    notification area and select "High performance", or perform the following:
    1. Click on Start, and then click on Control Panel.
    2. Click on System and Maintenance, and then click on Power Options.
    3. Set the active power plan to "High performance".
    4. Close the Control Panel window.
    I hope that this information proves to be useful to you, have a great day,
    Regards,
    Kristan M. Kenney
    "scrooge" wrote:
    > hi
    > thanks mike
    > scrooge
  5. #5
    scrooge's Avatar
      Thread Starter
    thanks for your help
    mike
  6. #6
    Ah! Thanks Kris.
    Andre
    "Kristan M. Kenney [MVP]" <KristanMKenneyMVP@xxxxxx>
    wrote in message news:69DC9541-02F1-4E77-85DE-7374E9D8FCC2@xxxxxx
    > Regards,
    > Kristan M. Kenney
    > rights.
    > "scrooge" wrote:
    >> hi
    >> thanks mike
    >> scrooge
power saving settings problems?
Power Saving Changing Settings on it's Own. SuperFuzz General Discussion 1 16 Mar 2009
Alter (auto) Power settings when plugged in or on Battery Power? Duneed Vista performance & maintenance 1 12 Mar 2009
Vista power settings - power button functionality phase4 Vista installation & setup 4 09 Jul 2008
CPU power saving Mirko Vista General 3 01 Feb 2007
Power Saving Options - LCD Monitor David M. Carney Vista General 4 19 Sep 2006
