| Guest | An installed application starts in 8-bit mode instead of 32-bit. Control CI installed Borland Delphi 3 Professional, a 32-bit Windows Development Environment, on my Acer Aspire computer with Windows Vista Home Premium operating system. I set compatibility to WIN98 and 256 color mode, but each time I start the application my display resets down to low resolution 8-bit color mode. When I exit the application, the display reverts back to high resolution 32-bit mode. I can go into Control Panel and Adjust Screen Resolution back up to high 32-bit while the application is running, and then everything looks fine, but the application goes back to low resolution 8-bit mode every time it is started. Can someone please help me solve this perplexing problem? Thank you for any assistance and suggestions. |
| Guest | RE: An installed application starts in 8-bit mode instead of 32-bit. Contact Borland for an update. App compat mode is there to shim applications to give them some ability to work (which yours does), but its not meant as a workaround for software that needs updated. Joseph W. Conway, MCSE Windows Server Group This posting is provided "AS IS" with no warranties, and confers no rights. |
| Guest | RE: An installed application starts in 8-bit mode instead of 32-bi Actually, I solved this problem already by removing the 256 color checkmark from the compatibilty window. Thanks for the try, but Borland doesn't give much of any assistance to owners of older software. They want you to buy the latest version of DELPHI for about $900, of course. For other people who are having problems with Borland software, or any other software that utilizes the Borland Database Engine (BDE) on a Vista equiped computer, please see the fix for this at the following address: http://forums.about.com/n/pfx/forum....lphi&tid=16087 ""Joseph Conway [MSFT]"" wrote: Quote: > Contact Borland for an update. App compat mode is there to shim > applications to give them some ability to work (which yours does), but its > not meant as a workaround for software that needs updated. > > Joseph W. Conway, MCSE > Windows Server Group > > This posting is provided "AS IS" with no warranties, and confers no rights. > > |
| Guest | RE: An installed application starts in 8-bit mode instead of 32-bi Thanks for information. I knew they might not have support for it but I personally dont use Borland so I wasnt sure. Glad you got it worked out. Joseph W. Conway, MCSE Windows Server Group This posting is provided "AS IS" with no warranties, and confers no rights. |
| Resistance is Futile | Re: An installed application starts in 8-bit mode instead of 32-bit. Rickoff, on the subject of Borland software, Delphi in partular, you wouldn't happen to know of any freeware database components for Delphi that will allow the creation of database programs that do not use BDE and does not require runtime support DLLs? Perhaps something that uses XML? |
| Vista starts in Safe Mode all the time | Vista General | |||
| Word 2007 always starts in safe mode | Microsoft Office | |||
| Computer only starts in Safe Mode after upgrades went through | Vista General | |||
| MS-DOS program starts only in full screen mode from command line | Vista General | |||
