Vista Tutorial - keys & SHIFT keys not working properly in Vista Home Premium
Old 10-19-2007   #1 (permalink)
mollydooka
Guest
I have just bought a Toshiba A200 notebook pre-installed with Vista Home
Premium, & I am having trouble with 3 key commands: when I press the ` key,
nothing happens, pressing it again gives me twosymbols: ``. Same with the
apostrophe key: ' (i.e. nothing first key press, '' after 2nd key press);
also pressing SHIFT with those 2 keys has the same result, viz: ~~, and "",
and SHIFT plus the 6 key has the same problem: ^^
Does anyone have a fix, couldn't find one on the Help & Support section?
Thanks, Michael, Perth, Australia
Old 10-19-2007   #2 (permalink)
Andre Da Costa[ActiveWin]
Guest
Re: keys & SHIFT keys not working properly in Vista Home Premium
Have you contacted Toshiba Support about this issue? Sounds more like
hardware than a software issue.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"mollydooka" <mollydooka@xxxxxx> wrote in message
news:ACD385C8-9B53-4A6E-A1B6-201FF6020677@xxxxxx
> key,
Wireless Desktop 600 F keys not working properly General Discussion
Up/down left/right arrow keys not working properly Vista General
Multimedia keys, Vista Home Premium Vista hardware & devices
Ctrl Alt Shift keys display? Vista General
Remote Desktop: Keys Ctrl, Alt, Shift do not function Vista networking & sharing
