Monitor Way to dark Worked just fine on xp
  1. #1
    Waffleman Guest
    I Just upgraded to vista from xp and everything working fine except that the
    display is Just too Dark. I've turned the contrast and brightness up all the
    way but the display is still too dark. Please help PS I'm not a programmer
    pleas answer the question in English that i can comprehend.
    Thx
  2. #2
    Mick Murphy Guest
    RE: Monitor Way to dark Worked just fine on xp
    Right-click on the empty Desktop> Personalise> change to your heart's content
    > Thx
  3. #3
    Andre Da Costa[ActiveWin] Guest
    Re: Monitor Way to dark Worked just fine on xp
    Have you tried turning off AERO? Following on Micks path, click Themes, then
    click in the Themes list box and select Windows Classic and see if thats
    better for you.
    Andre
    Blog: http://adacosta.spaces.live.com
    My Vista Quickstart Guide:
    http://adacosta.spaces.live.com/blog...3DB!9709.entry
    "Waffleman" <Waffleman@xxxxxx> wrote in message
    news:01958B49-4515-4DC1-9035-A12B9C2C1E14@xxxxxx
    >the
    > the
    > Thx
  4. #4
    Lang Murphy Guest
    >the
    > the
    > Thx
    Vista is using different drivers for your video card and your monitor than
    XP. Check for updated drivers for both. The video card is the important one.
    Do you know if you were using a generic monitor driver under XP or a model
    specific driver? If the former, forget about it. If the latter, you might
    want to check to see if Vista is using the model specific driver or just a
    generic driver.
    Lang
Monitor Way to dark Worked just fine on xp problems?
e-mail worked fine now cannot send rbishir Vista mail 1 30 Oct 2009
Solved Word 2007 ONLY causing print error - worked fine before meltie Microsoft Office 2 14 Oct 2009
cant sign in to live messenger 2009 8089 worked fine in 8.1 Camlawnman Live Messenger 0 20 Sep 2009
Cd drive is not installing, worked fine yesterday Altimax98 Vista General 0 25 Nov 2006
Install Worked Fine.....But will only boot into Safe Mode Marc Vista installation & setup 0 09 Jun 2006
