| | Control Panel does not work I am running Vista basic, and when I try to go into Control Panel, a message comes up saying that Windows Explorer has stopped working, and then explorer restarts. It does not get into the control panel at all. This happened once before, and I formatted the hard drive and started from scratch to rectify the problem It was fine for a couple of weeks, but now I have the same problem again. I do keep up to date with Windows update. Please help!! |
| | Re: Control Panel does not work > > Open the Run command (Win + R) type in SFC /SCANNOW and click Enter, Quote: Quote: > > click > > Continue on the UAC dialog that appears. Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Rob Gardner" <RobGardner@xxxxxx> wrote in message news:C8F43012-957D-441A-92D2-5E0F7915EDB9@xxxxxx Quote: >I am running Vista basic, and when I try to go into Control Panel, a >message > comes up saying that Windows Explorer has stopped working, and then > explorer > restarts. It does not get into the control panel at all. This happened > once > before, and I formatted the hard drive and started from scratch to rectify > the problem It was fine for a couple of weeks, but now I have the same > problem again. I do keep up to date with Windows update. Please help!! |
| | Re: Control Panel does not work Rob Gardner wrote: Quote: > I am running Vista basic, and when I try to go into Control Panel, a > message comes up saying that Windows Explorer has stopped working, > and then explorer restarts. It does not get into the control panel at > all. This happened once before, and I formatted the hard drive and > started from scratch to rectify the problem It was fine for a couple > of weeks, but now I have the same problem again. I do keep up to > date with Windows update. Please help!! If you have Nero InCD installed...the following article may be useful: (936686) Icons are missing from Control Panel, or you cannot start Control Panel, the Welcome Center, or games in Windows Vista http://support.microsoft.com/kb/936686/en-us -- John Inzer MS Picture It! - Digital Image MVP Digital Image Highlights and FAQs http://tinyurl.com/aczzp Notice This is not tech support I am a volunteer Solutions that work for me may not work for you Proceed at your own risk |
| Control panel doesn't work. | Vista General | |||
| Control Panel/ Color Scheme doesn't work:( | Vista performance & maintenance | |||
| mail and fax in control panel won't work | Vista General | |||
| Control panel does not work | Vista General | |||
| Control Panel does not work | Vista General | |||
