| | system restore points not created automatically Hi, I have automatic creating of system restore points turned on but it does not save automatically any points. I can create them manually without any problem though and they are not being deleted. This has been like that since I bought my brand new computer. I have only Vista OS, no disc cleaners etc. Any ideas how to get the system create the points automatically? -- /daissy |
| | Re: system restore points not created automatically * daissy: Quote: > Hi, > > I have automatic creating of system restore points turned on but it does not > save automatically any points. I can create them manually without any problem > though and they are not being deleted. This has been like that since I bought > my brand new computer. I have only Vista OS, no disc cleaners etc. > > Any ideas how to get the system create the points automatically? started in Services. Administrative Tools>Services Or, type "services.msc" into Start menu's search, press enter. -Michael |
| | Re: system restore points not created automatically I checked the task scheduler and it is both set to automatic and started, so the reason must be somewhere else. -- /daissy "MICHAEL" wrote: Quote: > * daissy: Quote: > > Hi, > > > > I have automatic creating of system restore points turned on but it does not > > save automatically any points. I can create them manually without any problem > > though and they are not being deleted. This has been like that since I bought > > my brand new computer. I have only Vista OS, no disc cleaners etc. > > > > Any ideas how to get the system create the points automatically? > Check to see if "Task Scheduler" is set to "Automatic" and is > started in Services. > > Administrative Tools>Services > > Or, type "services.msc" into Start menu's search, press enter. > > > -Michael > |
| | Re: system restore points not created automatically * daissy: Quote: > I checked the task scheduler and it is both set to automatic and started, so > the reason must be somewhere else. Look under Windows Logs>Application, see if you can find any "Warning" or "Error" that says "System Restore". Especially, the !Error events. Those could be preceded by other warnings, maybe for "VSS". While you're there, look under Windows>System, too. This may help narrow the problem down. -Michael |
| | Re: system restore points not created automatically Yes, there are error and warning events that repeat almost everday. 2 types of error events from System Restore and one type of warning from VSS. I copy those 3 types below. I diddn't find anything warning under "system" logs searching by "restore" and "vss" keywords. I checked the web on that without any results which would help me with my level of technical knowledge, so any help is much appreciated ![]() Log Name: Application Source: System Restore Date: 2007-10-12 21:55:40 Event ID: 8210 Task Category: None Level: Error Keywords: Classic User: N/A Computer: Kasia-PC Description: The scheduled restore point could not be created. Additional information: (0x800423f4). Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="System Restore" /> <EventID Qualifiers="0">8210</EventID> <Level>2</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2007-10-12T19:55:40.000Z" /> <EventRecordID>9737</EventRecordID> <Channel>Application</Channel> <Computer>Kasia-PC</Computer> <Security /> </System> <EventData> <Data>0x800423f4</Data> <Binary>0000000000000000D200000000000000574C29CE5843BE27E26C1C000000000000000000</Binary> </EventData> </Event> Log Name: Application Source: System Restore Date: 2007-10-12 21:55:40 Event ID: 8193 Task Category: None Level: Error Keywords: Classic User: N/A Computer: Kasia-PC Description: Failed to create restore point on volume (Process = C:\Windows\system32\rundll32.exe /d srrstr.dll,ExecuteScheduledSPPCreation; Descripton = Scheduled Checkpoint; Hr = 0x800423f4). Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="System Restore" /> <EventID Qualifiers="0">8193</EventID> <Level>2</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2007-10-12T19:55:40.000Z" /> <EventRecordID>9736</EventRecordID> <Channel>Application</Channel> <Computer>Kasia-PC</Computer> <Security /> </System> <EventData> <Data>C:\Windows\system32\rundll32.exe /d srrstr.dll,ExecuteScheduledSPPCreation</Data> <Data>Scheduled Checkpoint</Data> <Data>0x800423f4</Data> <Binary>F423048002020000D60100000000000032CA19E58CAF4DCB010000000000000000000000</Binary> </EventData> </Event> Log Name: Application Source: VSS Date: 2007-10-12 21:55:39 Event ID: 12290 Task Category: None Level: Warning Keywords: Classic User: N/A Computer: Kasia-PC Description: Volume Shadow Copy Service warning: ASR writer Error 0x80070037. hr = 0x00000000. Operation: PrepareForBackup event PrepareForBackup event Context: Execution Context: ASR Writer Execution Context: Writer Writer Class Id: {be000cbe-11fe-4426-9c58-531aa6355fc4} Writer Name: ASR Writer Writer Instance ID: {97ee6ecb-4fdf-49ef-96ad-2ae645cad48f} Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="VSS" /> <EventID Qualifiers="0">12290</EventID> <Level>3</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2007-10-12T19:55:39.000Z" /> <EventRecordID>9735</EventRecordID> <Channel>Application</Channel> <Computer>Kasia-PC</Computer> <Security /> </System> <EventData> <Data>ASR writer Error 0x80070037</Data> <Data>0x00000000</Data> <Data> Operation: PrepareForBackup event PrepareForBackup event Context: Execution Context: ASR Writer Execution Context: Writer Writer Class Id: {be000cbe-11fe-4426-9c58-531aa6355fc4} Writer Name: ASR Writer Writer Instance ID: {97ee6ecb-4fdf-49ef-96ad-2ae645cad48f}</Data> <Binary>2D20436F64653A20575254415352574330303030303231382D2043616C6C3A20575254415352574330303030303331332D205049443A202030303030303937362D205449443A202030303030363330382D20434D443A2020433A5C57696E646F77735C73797374656D33325C76737376632E6578652020202D20557365723A204E5420415554484F524954595C53595354454D20202020202D205369643A2020532D312D352D31382D204572726F723A41535220777269746572204572726F7220307838303037303033372020202020</Binary> </EventData> </Event> -- /daissy "MICHAEL" wrote: Quote: > * daissy: Quote: > > I checked the task scheduler and it is both set to automatic and started, so > > the reason must be somewhere else. > Type or copy/paste "eventvwr.msc" into the search bar, press enter. > > Look under Windows Logs>Application, see if you can find any "Warning" > or "Error" that says "System Restore". Especially, the !Error events. Those > could be preceded by other warnings, maybe for "VSS". > > While you're there, look under Windows>System, too. > > This may help narrow the problem down. > > > > -Michael > > |
| | #6 (permalink) |
| | Re: system restore points not created automatically * daissy: Quote: > Yes, there are error and warning events that repeat almost everday. 2 types > of error events from System Restore and one type of warning from VSS. I copy > those 3 types below. I diddn't find anything warning under "system" logs > searching by "restore" and "vss" keywords. > I checked the web on that without any results which would help me with my > level of technical knowledge, so any help is much appreciated ![]() -Michael |
| | #7 (permalink) |
| | Re: system restore points not created automatically It's Sony Vaio VGN-TZ150N with Vista Business 32 bits on OEM licence. I bought it in the US but stay now in Europe and my warranty does not work here, which is a huge pity taking into account amount of troubles I am experiencing and time it consumes to get it work properly. -- /daissy "MICHAEL" wrote: Quote: > * daissy: Quote: > > Yes, there are error and warning events that repeat almost everday. 2 types > > of error events from System Restore and one type of warning from VSS. I copy > > those 3 types below. I diddn't find anything warning under "system" logs > > searching by "restore" and "vss" keywords. > > I checked the web on that without any results which would help me with my > > level of technical knowledge, so any help is much appreciated ![]() > Who makes your computer? What's the specific model? > > > -Michael > |
| | #8 (permalink) |
| | Re: system restore points not created automatically * daissy: Quote: > It's Sony Vaio VGN-TZ150N with Vista Business 32 bits on OEM licence. I > bought it in the US but stay now in Europe and my warranty does not work > here, which is a huge pity taking into account amount of troubles I am > experiencing and time it consumes to get it work properly. Type "sysdm.cpl" into the search bar, press enter. Go to the "System Protection" tab. Uncheck all under "Available Disks". You'll get a pop-up window asking if you "Are sure you want to turn System restore off". It will be stopped after that and restore points deleted. Do some disk maintenance. Open up "Computer", right-click your C drive, Properties, Tools tab. Under "Error Checking", click "Check Now". A box will appear, there will be two options, check both. Then you'll get another box that says "Windows can not check this disk while it's in use", click "Schedule disk check". Normally, I would only suggest checking "Automatically fix errors", but just go ahead and check both. The scanning for bad sectors may take awhile, so be patient. Reboot. The disk check will start right after you reboot. Once you are back to your desktop. Force a defrag- type "cmd" into the search bar, at the very top of the results you will see "cmd.exe", right-click it and select "Run as Administrator". Copy/paste "defrag c: -v -w" into the command window. This will do a full defrag. By default, Vista defrag will skip 64 MB (or larger) file fragments. With the command you pasted, it will not. However, the defrag will take longer to complete. Be patient. If you want to, you can use the command, "defrag c: -v -r", which is the default for Vista defrag, it will skip those larger fragmented files, and complete faster. Once that's done, turn System Restore on. Only check your C drive (System drive). Be sure that while your going through these steps that you "Allow" the action if the UAC nag screen pops up. None of this may solve your problem. But, at least you will have a "cleaner" disk. We can always try something else. Take care, Michael |
| | #9 (permalink) |
| | Re: system restore points not created automatically Hi Daissy, This error (0x800423f4) keep popping up in these events. This error is caused by a bug in the driver for Intel ICH5R chipset that results in critical disk 0 not being marked as fixed hard disk. There is no workaround because. According to Intel, this version is not Windows Vista compatible: http://support.intel.com/support/chi.../CS-023616.htm Intel Matrix Storage Manager support http://support.intel.com/support/chipsets/imsm/ Intel Matrix Storage Manager downloads: http://downloadcenter.intel.com/filt...4&submit=Go%21 IntelĀ® Matrix Storage Manager - Frequently Asked Questions http://support.intel.com/support/chi...S-020785.htm#2 Regards, Bert Kinney MS-MVP Shell/User http://bertk.mvps.org Member: http://dts-l.org daissy wrote: Quote: > Yes, there are error and warning events that repeat almost everday. 2 types > of error events from System Restore and one type of warning from VSS. I copy > those 3 types below. I diddn't find anything warning under "system" logs > searching by "restore" and "vss" keywords. > I checked the web on that without any results which would help me with my > level of technical knowledge, so any help is much appreciated ![]() > > Log Name: Application > Source: System Restore > Date: 2007-10-12 21:55:40 > Event ID: 8210 > Task Category: None > Level: Error > Keywords: Classic > User: N/A > Computer: Kasia-PC > Description: > The scheduled restore point could not be created. Additional information: > (0x800423f4). > Event Xml: > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> > <System> > <Provider Name="System Restore" /> > <EventID Qualifiers="0">8210</EventID> > <Level>2</Level> > <Task>0</Task> > <Keywords>0x80000000000000</Keywords> > <TimeCreated SystemTime="2007-10-12T19:55:40.000Z" /> > <EventRecordID>9737</EventRecordID> > <Channel>Application</Channel> > <Computer>Kasia-PC</Computer> > <Security /> > </System> > <EventData> > <Data>0x800423f4</Data> > > > Log Name: Application > Source: System Restore > Date: 2007-10-12 21:55:40 > Event ID: 8193 > Task Category: None > Level: Error > Keywords: Classic > User: N/A > Computer: Kasia-PC > Description: > Failed to create restore point on volume (Process = > C:\Windows\system32\rundll32.exe /d srrstr.dll,ExecuteScheduledSPPCreation; > Descripton = Scheduled Checkpoint; Hr = 0x800423f4). > Event Xml: > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> > <System> > <Provider Name="System Restore" /> > <EventID Qualifiers="0">8193</EventID> > <Level>2</Level> > <Task>0</Task> > <Keywords>0x80000000000000</Keywords> > <TimeCreated SystemTime="2007-10-12T19:55:40.000Z" /> > <EventRecordID>9736</EventRecordID> > <Channel>Application</Channel> > <Computer>Kasia-PC</Computer> > <Security /> > </System> > <EventData> > <Data>C:\Windows\system32\rundll32.exe /d > srrstr.dll,ExecuteScheduledSPPCreation</Data> > <Data>Scheduled Checkpoint</Data> > <Data>0x800423f4</Data> > > > Log Name: Application > Source: VSS > Date: 2007-10-12 21:55:39 > Event ID: 12290 > Task Category: None > Level: Warning > Keywords: Classic > User: N/A > Computer: Kasia-PC > Description: > Volume Shadow Copy Service warning: ASR writer Error 0x80070037. hr = > 0x00000000. > > Operation: > PrepareForBackup event > PrepareForBackup event > > Context: > Execution Context: ASR Writer > Execution Context: Writer > Writer Class Id: {be000cbe-11fe-4426-9c58-531aa6355fc4} > Writer Name: ASR Writer > Writer Instance ID: {97ee6ecb-4fdf-49ef-96ad-2ae645cad48f} > Event Xml: > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> > <System> > <Provider Name="VSS" /> > <EventID Qualifiers="0">12290</EventID> > <Level>3</Level> > <Task>0</Task> > <Keywords>0x80000000000000</Keywords> > <TimeCreated SystemTime="2007-10-12T19:55:39.000Z" /> > <EventRecordID>9735</EventRecordID> > <Channel>Application</Channel> > <Computer>Kasia-PC</Computer> > <Security /> > </System> > <EventData> > <Data>ASR writer Error 0x80070037</Data> > <Data>0x00000000</Data> > <Data> > > Operation: > PrepareForBackup event > PrepareForBackup event > > Context: > Execution Context: ASR Writer > Execution Context: Writer > Writer Class Id: {be000cbe-11fe-4426-9c58-531aa6355fc4} > Writer Name: ASR Writer > Writer Instance ID: {97ee6ecb-4fdf-49ef-96ad-2ae645cad48f}</Data> |
| | #10 (permalink) |
| | Re: system restore points not created automatically Hi Bert, I checked my Intel chipset properties and under system devices listing it says that I have ICH7 Family. I also had a look at requirements for Intel Matrix Storage Manager which say that I would have to have some Intel storage controller installed, and the only storage controller I have is from Microsoft iSCSI Initiator. But I am not sure if need this Intel Matrix Storage Manager at all, on the websit it says it is not required for standalone SATA hard drivers, but I dont know how to check what kind of drive I have. If it is not the bug in ICH5, than maybe there is a workaround? Regards, -- /daissy "Bert Kinney" wrote: Quote: > Hi Daissy, > > This error (0x800423f4) keep popping up in these events. > > This error is caused by a bug in the driver for Intel ICH5R chipset that > results in critical disk 0 not being marked as fixed hard disk. There is no > workaround because. According to Intel, this version is not Windows Vista > compatible: http://support.intel.com/support/chi.../CS-023616.htm > > Intel Matrix Storage Manager support > http://support.intel.com/support/chipsets/imsm/ > > Intel Matrix Storage Manager downloads: > http://downloadcenter.intel.com/filt...4&submit=Go%21 > > IntelĀ® Matrix Storage Manager - Frequently Asked Questions > http://support.intel.com/support/chi...S-020785.htm#2 > > Regards, > Bert Kinney MS-MVP Shell/User > http://bertk.mvps.org > Member: http://dts-l.org > > daissy wrote: Quote: > > Yes, there are error and warning events that repeat almost everday. 2 types > > of error events from System Restore and one type of warning from VSS. I copy > > those 3 types below. I diddn't find anything warning under "system" logs > > searching by "restore" and "vss" keywords. > > I checked the web on that without any results which would help me with my > > level of technical knowledge, so any help is much appreciated ![]() > > > > Log Name: Application > > Source: System Restore > > Date: 2007-10-12 21:55:40 > > Event ID: 8210 > > Task Category: None > > Level: Error > > Keywords: Classic > > User: N/A > > Computer: Kasia-PC > > Description: > > The scheduled restore point could not be created. Additional information: > > (0x800423f4). > > Event Xml: > > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> > > <System> > > <Provider Name="System Restore" /> > > <EventID Qualifiers="0">8210</EventID> > > <Level>2</Level> > > <Task>0</Task> > > <Keywords>0x80000000000000</Keywords> > > <TimeCreated SystemTime="2007-10-12T19:55:40.000Z" /> > > <EventRecordID>9737</EventRecordID> > > <Channel>Application</Channel> > > <Computer>Kasia-PC</Computer> > > <Security /> > > </System> > > <EventData> > > <Data>0x800423f4</Data> > > > > > > Log Name: Application > > Source: System Restore > > Date: 2007-10-12 21:55:40 > > Event ID: 8193 > > Task Category: None > > Level: Error > > Keywords: Classic > > User: N/A > > Computer: Kasia-PC > > Description: > > Failed to create restore point on volume (Process = > > C:\Windows\system32\rundll32.exe /d srrstr.dll,ExecuteScheduledSPPCreation; > > Descripton = Scheduled Checkpoint; Hr = 0x800423f4). > > Event Xml: > > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> > > <System> > > <Provider Name="System Restore" /> > > <EventID Qualifiers="0">8193</EventID> > > <Level>2</Level> > > <Task>0</Task> > > <Keywords>0x80000000000000</Keywords> > > <TimeCreated SystemTime="2007-10-12T19:55:40.000Z" /> > > <EventRecordID>9736</EventRecordID> > > <Channel>Application</Channel> > > <Computer>Kasia-PC</Computer> > > <Security /> > > </System> > > <EventData> > > <Data>C:\Windows\system32\rundll32.exe /d > > srrstr.dll,ExecuteScheduledSPPCreation</Data> > > <Data>Scheduled Checkpoint</Data> > > <Data>0x800423f4</Data> > > > > > > Log Name: Application > > Source: VSS > > Date: 2007-10-12 21:55:39 > > Event ID: 12290 > > Task Category: None > > Level: Warning > > Keywords: Classic > > User: N/A > > Computer: Kasia-PC > > Description: > > Volume Shadow Copy Service warning: ASR writer Error 0x80070037. hr = > > 0x00000000. > > > > Operation: > > PrepareForBackup event > > PrepareForBackup event > > > > Context: > > Execution Context: ASR Writer > > Execution Context: Writer > > Writer Class Id: {be000cbe-11fe-4426-9c58-531aa6355fc4} > > Writer Name: ASR Writer > > Writer Instance ID: {97ee6ecb-4fdf-49ef-96ad-2ae645cad48f} > > Event Xml: > > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> > > <System> > > <Provider Name="VSS" /> > > <EventID Qualifiers="0">12290</EventID> > > <Level>3</Level> > > <Task>0</Task> > > <Keywords>0x80000000000000</Keywords> > > <TimeCreated SystemTime="2007-10-12T19:55:39.000Z" /> > > <EventRecordID>9735</EventRecordID> > > <Channel>Application</Channel> > > <Computer>Kasia-PC</Computer> > > <Security /> > > </System> > > <EventData> > > <Data>ASR writer Error 0x80070037</Data> > > <Data>0x00000000</Data> > > <Data> > > > > Operation: > > PrepareForBackup event > > PrepareForBackup event > > > > Context: > > Execution Context: ASR Writer > > Execution Context: Writer > > Writer Class Id: {be000cbe-11fe-4426-9c58-531aa6355fc4} > > Writer Name: ASR Writer > > Writer Instance ID: {97ee6ecb-4fdf-49ef-96ad-2ae645cad48f}</Data> |
| What prevents Vista from creating restore points automatically? | Vista performance & maintenance | |||
| Automatic Restore Points not being created | Vista performance & maintenance | |||
| System Restore Deleting Restore Points Automatically.... | Vista General | |||
| System Restore points are not created when using RAS | Vista hardware & devices | |||
| User created system restore points disappear | Vista General | |||
