| | System Instability I there. I have bought an Acer PC which came pre-loaded with a 90 day trial version of Norton Internet Security... I decided i didn't want this software installed,and prefered to use my VexiraAnti-virus... Un-installing Norton and putting Vexira on seems to have caused major system instability where the PC crashes very frequently.. I finally did a recovery from the hidden partition and left the Vexira AV off.. The PC now runs like a dream,but i'm wondering what things Norton left behind for it to clash like that and whether i should stick with Norton. thanks for any replies, dave |
| | Re: System Instability Hi, There is the symclean tool from Symantec, but I understand that it has caused some problems with networking in Vista. They may have updated the tool to address this by now, I haven't checked. Assuming that Vexira was a Vista compatible version, did the problems start after uninstalling Norton's? Or after installing Vexira? While it's possible that it may be a conflict with something left behind, it's also possible that the problem was one of the new services installed by the new AV program. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Dave B" <not@xxxxxx> wrote in message news:unSAg%23hFIHA.936@xxxxxx Quote: >I there. > I have bought an Acer PC which came pre-loaded with a 90 day trial version > of Norton Internet Security... > I decided i didn't want this software installed,and prefered to use my > VexiraAnti-virus... > > Un-installing Norton and putting Vexira on seems to have caused major > system instability where the PC crashes very frequently.. > I finally did a recovery from the hidden partition and left the Vexira AV > off.. > > The PC now runs like a dream,but i'm wondering what things Norton left > behind for it to clash like that and whether i should stick with Norton. > > thanks for any replies, > dave > > > > |
| | Re: System Instability "> Assuming that Vexira was a Vista compatible version, did the problems start Quote: > after uninstalling Norton's? Or after installing Vexira? While it's > possible that it may be a conflict with something left behind, it's also > possible that the problem was one of the new services installed by the new > AV program. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > Thanks for the reply!! Vexira is Vista compatible but the problems seem to start when this is installed. I've un-installed it and the system is now rock-solid... I wasn't too pleased with the fact that Norton comes as part of the install/recovery...doesn't give you much choice really... david |
| | Re: System Instability Norton in house products like the antivirus is one of the WORSE software ever built by man!!!! Only Vista itself is worse... At least you got rid of Norton... soon when your awareness grows, you will abandon vista as well. Good luck! "Dave B" <not@xxxxxx> wrote in message news:unSAg%23hFIHA.936@xxxxxx Quote: >I there. > I have bought an Acer PC which came pre-loaded with a 90 day trial version > of Norton Internet Security... > I decided i didn't want this software installed,and prefered to use my > VexiraAnti-virus... > > Un-installing Norton and putting Vexira on seems to have caused major > system instability where the PC crashes very frequently.. > I finally did a recovery from the hidden partition and left the Vexira AV > off.. > > The PC now runs like a dream,but i'm wondering what things Norton left > behind for it to clash like that and whether i should stick with Norton. > > thanks for any replies, > dave > > > > |
| | Re: System Instability sorry, not helpful for the OP, but i cannot hold it anymore (and im pretty sure im not the only one) tie various, would you please stop changing your name so we dont need to update our blocklist every now and then? please... |
| | #6 (permalink) |
| | Re: System Instability Hello, Explain why you want me on your block list. I will prove to you, that you need to remove me forever from your block list. "Jume" <jume@xxxxxx> wrote in message news:uHhZnxkFIHA.5208@xxxxxx Quote: > sorry, not helpful for the OP, but i cannot hold it anymore (and im pretty > sure im not the only one) > > tie various, would you please stop changing your name so we dont need to > update our blocklist every now and then? please... |
| | #7 (permalink) |
| | Re: System Instability Tie Various wrote: Quote: > Hello, > > Explain why you want me on your block list. > I will prove to you, that you need to remove me forever from your block > list. > > > > "Jume" <jume@xxxxxx> wrote in message > news:uHhZnxkFIHA.5208@xxxxxx > Quote: >>sorry, not helpful for the OP, but i cannot hold it anymore (and im pretty >>sure im not the only one) >> >>tie various, would you please stop changing your name so we dont need to >>update our blocklist every now and then? please... > > self-indulgent postings of obvious lies in a vain attempt to get noticed. You're one sick stupid as*hole that we all want to get rid of. In plain language...you're and idiot we don't want nor need! Leave...for good this time. Frank |
| pointer and cursor instability | Vista performance & maintenance | |||
| WLM instability? | Live Mail | |||
| Instability since installation of SP1. | Vista General | |||
| Activation Error & System Instability | Vista General | |||
| Presentation instability | Vista performance & maintenance | |||
