| | D-Link DWL-G520+ Connection Problem Hi, Has anyone managed to get the D-Link DWL-G520+ card working in Vista with the XP drivers? I'm using the v2.04 Ax driver from www.dlink.co.uk and it installs fine, but the card won't connect to my router properly. My router is a Netgear DG834G, set to wireless channel 11 and to automatically give out IP addresses. When Vista reports that my card has connected to the router the card has an IP address of 169.254.50.18 even though my router is giving out IP address from 192.168.0.2 and upwards. This suggests that the card hasn't connected to the router properly. Setting the IP address manually doesn't help. Also, when I look at the connection status it is sending out data but never receiving any back. One last thing i've noticed is that in the event viewer I keep getting this error: Microsoft-Windows-WLAN-AutoConfig Wireless network connection failed. Network SSID: apple BSS Type: Infrastructure Failure Reason: Driver disconnected. which probably isn't very good. This setup works fine under XP. Anyone have any ideas or suggestions? Thanks Gavin |
| | Re: D-Link DWL-G520+ Connection Problem You'll get it with Windows Update. Have a look at Optional update. cf. http://cjoint.com/?hixvyBXK2b -- Merzhin Brittany - France "Gavin Rouse" <GavinRouse@discussions.microsoft.com> wrote in message news:FA7C9FB8-074C-44FC-913A-82481D42CFD7@microsoft.com... > Hi, > > Has anyone managed to get the D-Link DWL-G520+ card working in Vista with > the XP drivers? > > I'm using the v2.04 Ax driver from www.dlink.co.uk and it installs fine, > but > the card won't connect to my router properly. > > My router is a Netgear DG834G, set to wireless channel 11 and to > automatically give out IP addresses. > > When Vista reports that my card has connected to the router the card has > an > IP address of 169.254.50.18 even though my router is giving out IP address > from 192.168.0.2 and upwards. This suggests that the card hasn't > connected > to the router properly. Setting the IP address manually doesn't help. > > Also, when I look at the connection status it is sending out data but > never > receiving any back. > > One last thing i've noticed is that in the event viewer I keep getting > this > error: > > Microsoft-Windows-WLAN-AutoConfig > > Wireless network connection failed. > > Network SSID: apple > BSS Type: Infrastructure > Failure Reason: Driver disconnected. > > which probably isn't very good. > > This setup works fine under XP. > > Anyone have any ideas or suggestions? > > Thanks > > Gavin > |
| | Re: D-Link DWL-G520+ Connection Problem Hi, Thanks for the reply. Unfortunately, if I run Windows Update it doesn't find that update (it says my PC is up to date) and I can't see how to search for it. If I try and update the driver manually Vista tells me my driver is up to date. Gavin "Merzhin" wrote: > You'll get it with Windows Update. Have a look at Optional update. > cf. http://cjoint.com/?hixvyBXK2b > > -- > Merzhin > Brittany - France > > > "Gavin Rouse" <GavinRouse@discussions.microsoft.com> wrote in message > news:FA7C9FB8-074C-44FC-913A-82481D42CFD7@microsoft.com... > > Hi, > > > > Has anyone managed to get the D-Link DWL-G520+ card working in Vista with > > the XP drivers? > > > > I'm using the v2.04 Ax driver from www.dlink.co.uk and it installs fine, > > but > > the card won't connect to my router properly. > > > > My router is a Netgear DG834G, set to wireless channel 11 and to > > automatically give out IP addresses. > > > > When Vista reports that my card has connected to the router the card has > > an > > IP address of 169.254.50.18 even though my router is giving out IP address > > from 192.168.0.2 and upwards. This suggests that the card hasn't > > connected > > to the router properly. Setting the IP address manually doesn't help. > > > > Also, when I look at the connection status it is sending out data but > > never > > receiving any back. > > > > One last thing i've noticed is that in the event viewer I keep getting > > this > > error: > > > > Microsoft-Windows-WLAN-AutoConfig > > > > Wireless network connection failed. > > > > Network SSID: apple > > BSS Type: Infrastructure > > Failure Reason: Driver disconnected. > > > > which probably isn't very good. > > > > This setup works fine under XP. > > > > Anyone have any ideas or suggestions? > > > > Thanks > > > > Gavin > > > |
| | Re: D-Link DWL-G520+ Connection Problem If you're sure that the latest driver is not already installed then go to the D-link site and download it and manually install it through the Device Manager. "Gavin Rouse" <GavinRouse@discussions.microsoft.com> wrote in message news:4B2AFC04-DAE5-4DDF-8EC4-6BFAAD5C867F@microsoft.com... > Hi, > > Thanks for the reply. > > Unfortunately, if I run Windows Update it doesn't find that update (it > says > my PC is up to date) and I can't see how to search for it. > > If I try and update the driver manually Vista tells me my driver is up to > date. > > Gavin > > "Merzhin" wrote: > >> You'll get it with Windows Update. Have a look at Optional update. >> cf. http://cjoint.com/?hixvyBXK2b >> >> -- >> Merzhin >> Brittany - France >> >> >> "Gavin Rouse" <GavinRouse@discussions.microsoft.com> wrote in message >> news:FA7C9FB8-074C-44FC-913A-82481D42CFD7@microsoft.com... >> > Hi, >> > >> > Has anyone managed to get the D-Link DWL-G520+ card working in Vista >> > with >> > the XP drivers? >> > >> > I'm using the v2.04 Ax driver from www.dlink.co.uk and it installs >> > fine, >> > but >> > the card won't connect to my router properly. >> > >> > My router is a Netgear DG834G, set to wireless channel 11 and to >> > automatically give out IP addresses. >> > >> > When Vista reports that my card has connected to the router the card >> > has >> > an >> > IP address of 169.254.50.18 even though my router is giving out IP >> > address >> > from 192.168.0.2 and upwards. This suggests that the card hasn't >> > connected >> > to the router properly. Setting the IP address manually doesn't help. >> > >> > Also, when I look at the connection status it is sending out data but >> > never >> > receiving any back. >> > >> > One last thing i've noticed is that in the event viewer I keep getting >> > this >> > error: >> > >> > Microsoft-Windows-WLAN-AutoConfig >> > >> > Wireless network connection failed. >> > >> > Network SSID: apple >> > BSS Type: Infrastructure >> > Failure Reason: Driver disconnected. >> > >> > which probably isn't very good. >> > >> > This setup works fine under XP. >> > >> > Anyone have any ideas or suggestions? >> > >> > Thanks >> > >> > Gavin >> > >> |
| D-link DWA-547 Connection problem | Vista hardware & devices | |||
| D-Link DWL-G520 Vista Driver | Vista hardware & devices | |||
| D-Link DWL-G520+ Connection Problem | Vista networking & sharing | |||
