| | Still having issues with empty control panel, desktop properties I earlier posted for info or tips on fixing the empty or disappearing control panel and now i noticed my desktop properties is having the same issue. I tried the following fix but it didnt work http://support.microsoft.com/kb/936686/en-us the only way to fix it very temporarily is to shut down and restart under system properties is the software liscene service. this is getting VERY annoying, is there any permament solutions? thanx |
| | Re: Still having issues with empty control panel, desktop properties * Zakspeed: Quote: > I earlier posted for info or tips on fixing the empty or disappearing > control panel and now i noticed my desktop properties is having the same > issue. > I tried the following fix but it didnt work > http://support.microsoft.com/kb/936686/en-us > the only way to fix it very temporarily is to shut down and restart under > system properties is the software liscene service. this is getting VERY > annoying, is there any permament solutions? > thanx set to "Automatic" and both started? -Michael |
| | Re: Still having issues with empty control panel, desktop properties For Control Panel, try this: Try this: 1) Launch services.msc from a run command 2) Find the SLUNotify service & stop it 3) Find the Software Licensing service & stop it (it may say that ReadyBoost needs that service to run; stop it anyway) 4) Restart both services, starting with Software Licensing -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Zakspeed" <thirose@xxxxxx> wrote in message news:7RTTi.140590$th2.19146@xxxxxx Quote: >I earlier posted for info or tips on fixing the empty or disappearing >control panel and now i noticed my desktop properties is having the same >issue. > I tried the following fix but it didnt work > http://support.microsoft.com/kb/936686/en-us > the only way to fix it very temporarily is to shut down and restart under > system properties is the software liscene service. this is getting VERY > annoying, is there any permament solutions? > thanx > |
| | Re: Still having issues with empty control panel, desktop properties Zakspeed wrote: Quote: > I earlier posted for info or tips on fixing the empty or disappearing > control panel and now i noticed my desktop properties is having the > same issue. > I tried the following fix but it didnt work > http://support.microsoft.com/kb/936686/en-us > the only way to fix it very temporarily is to shut down and restart > under system properties is the software liscene service. this is > getting VERY annoying, is there any permament solutions? > thanx Just wondering...did you try requesting the hotfix suggested in the 936686 article? (936686) Icons are missing from Control Panel, or you cannot start Control Panel, the Welcome Center, or games in Windows Vista http://support.microsoft.com/kb/936686/en-us Hotfix info: (929637) Error message during Windows Vista startup if the Nero InCD program is installed and if the "Special pool" feature is enabled in the Driver Verifier utility: "Stop 00000050" http://support.microsoft.com/kb/929637/ -- John Inzer MS Picture It! - Digital Image MVP Digital Image Highlights and FAQs http://tinyurl.com/aczzp Notice This is not tech support I am a volunteer Solutions that work for me may not work for you Proceed at your own risk |
| | Re: Still having issues with empty control panel, desktop properties i noticed that SLUI notification is set to auto start, but it is not started. should this be started at all times and how can i set it to start upon reboot? "MICHAEL" <u158627_emr2@xxxxxx> wrote in message news:Oc8NfYrFIHA.5228@xxxxxx Quote: >* Zakspeed: Quote: >> I earlier posted for info or tips on fixing the empty or disappearing >> control panel and now i noticed my desktop properties is having the same >> issue. >> I tried the following fix but it didnt work >> http://support.microsoft.com/kb/936686/en-us >> the only way to fix it very temporarily is to shut down and restart under >> system properties is the software liscene service. this is getting VERY >> annoying, is there any permament solutions? >> thanx > Do you have "Software Licensing" and "SL UI Notification" > set to "Automatic" and both started? > > > -Michael |
| | #6 (permalink) |
| | Re: Still having issues with empty control panel, desktop properties as stated, this is just a temp fix. any permamnet solutions? "Andre Da Costa[ActiveWin]" <andred25@xxxxxx> wrote in message news:eIzDXcrFIHA.1188@xxxxxx Quote: > For Control Panel, try this: > Try this: > 1) Launch services.msc from a run command > 2) Find the SLUNotify service & stop it > 3) Find the Software Licensing service & stop it (it may say that > ReadyBoost > needs that service to run; stop it anyway) > 4) Restart both services, starting with Software Licensing > -- > Andre > Blog: http://adacosta.spaces.live.com > My Vista Quickstart Guide: > http://adacosta.spaces.live.com/blog...3DB!9709.entry > > "Zakspeed" <thirose@xxxxxx> wrote in message > news:7RTTi.140590$th2.19146@xxxxxx Quote: >>I earlier posted for info or tips on fixing the empty or disappearing >>control panel and now i noticed my desktop properties is having the same >>issue. >> I tried the following fix but it didnt work >> http://support.microsoft.com/kb/936686/en-us >> the only way to fix it very temporarily is to shut down and restart under >> system properties is the software liscene service. this is getting VERY >> annoying, is there any permament solutions? >> thanx >> > |
| | #7 (permalink) |
| | Re: Still having issues with empty control panel, desktop properties Open up the properties for SLUI Notification, go to the "Dependencies" tab. Look to make sure you don't have any of those Services disabled; "COM Event System", "Remote Procedure Call (RPC)", "Network List Service", "Network Location Awareness", "Software Licensing". -Michael * Zakspeed: Quote: > i noticed that SLUI notification is set to auto start, but it is not > started. should this be started at all times and how can i set it to start > upon reboot? > > > > "MICHAEL" <u158627_emr2@xxxxxx> wrote in message > news:Oc8NfYrFIHA.5228@xxxxxx Quote: >> * Zakspeed: Quote: >>> I earlier posted for info or tips on fixing the empty or disappearing >>> control panel and now i noticed my desktop properties is having the same >>> issue. >>> I tried the following fix but it didnt work >>> http://support.microsoft.com/kb/936686/en-us >>> the only way to fix it very temporarily is to shut down and restart under >>> system properties is the software liscene service. this is getting VERY >>> annoying, is there any permament solutions? >>> thanx >> set to "Automatic" and both started? >> >> >> -Michael |
| Control Panel is EMPTY, Lost all printers | Windows Updates | |||
| Control panel empty, personalize not working, etc | Vista performance & maintenance | |||
| Why is my; Control Panel Empty, the 3D Scrolling not working? | Vista General | |||
| How can i fix the empty control panel issue? | Vista General | |||
| Control Panel Empty Issue | Vista General | |||
