| | Dumb down - 64 bit to 32 bit Is it posssible to install 32 bit Vista over 64 bit? There are so many drivers that I can't get with 64 bit, especially soundcards. After a year I am ready to throw in the towel and go to 32 bit. Thanks. |
| | Re: Dumb down - 64 bit to 32 bit You will have to do a clean install.. boot from the 32bit DVD, delete and recreate the partition(s).. save important stuff first.. -- Mike Hall - MVP http://msmvps.com/blogs/mikehall/default.aspx Posting Productively.. http://www.dts-l.org/goodpost.htm "Ali Mony" <Jr@xxxxxx> wrote in message news:u2C9EG0FIHA.936@xxxxxx Quote: > Is it posssible to install 32 bit Vista over 64 bit? There are so many > drivers that I can't get with 64 bit, especially soundcards. After a year > I am ready to throw in the towel and go to 32 bit. Thanks. |
| | Re: Dumb down - 64 bit to 32 bit "Ali Mony" <Jr@xxxxxx> wrote: Quote: >Is it posssible to install 32 bit Vista over 64 bit? There are so many >drivers that I can't get with 64 bit, especially soundcards. After a year I >am ready to throw in the towel and go to 32 bit. Thanks. to install the new OS from scratch. -- Tim Slattery MS MVP(Shell/User) Slattery_T@xxxxxx http://members.cox.net/slatteryt |
| | Re: Dumb down - 64 bit to 32 bit If true that would be unusual. Care to tell us which drivers are 32-bit only? Which soundcards? Ali Mony wrote: Quote: > Is it posssible to install 32 bit Vista over 64 bit? There are so many > drivers that I can't get with 64 bit, especially soundcards. After a > year I am ready to throw in the towel and go to 32 bit. Thanks. |
| | Re: Dumb down - 64 bit to 32 bit Thanks for the replies, guys. I may do that at some point (reformat) and reinstall. The drivers I care about are M-Audio Audiophile 192 soundcard. Not available even in beta. I have a souncard that I haven't been able to use for a year and am using a cheapo that is built in the motherboard. I have Vista Ultimate 32 bit on another computer and am using their USB drivers (just now in beta) with an M-Audio Mobile-Pre soundcard. Also, for music, is Adobe Audition 3 that's coming out next month. But it will only be available in Vista 32 bit (per their website). I love Vista but to be honest, in using Vista Ultimate 64 bit and 32 bit on different computers, I can't tell the difference. Except for driver availability. "cvp" <goaway@xxxxxx> wrote in message news:euAFkt1FIHA.4584@xxxxxx Quote: > If true that would be unusual. Care to tell us which drivers are 32-bit > only? Which soundcards? > > Ali Mony wrote: Quote: >> Is it posssible to install 32 bit Vista over 64 bit? There are so many >> drivers that I can't get with 64 bit, especially soundcards. After a year >> I am ready to throw in the towel and go to 32 bit. Thanks. |
| | #6 (permalink) |
| | Re: Dumb down - 64 bit to 32 bit Vista 64bit comes into its own running 64bit applications. For some reason, the general belief is that it will be much faster, even when only running 32bit apps that have a 2gb limit anyway, many of which never get close to using that much. 64bit hardware exists because it is the way forward, and can run 32 and 64bit stuff, but that does not necessarily mean that one should run Vista/XP64 just for the sake of it. -- Mike Hall - MVP http://msmvps.com/blogs/mikehall/default.aspx Posting Productively.. http://www.dts-l.org/goodpost.htm "Ali Mony" <Jr@xxxxxx> wrote in message news:%23hJ0tJ9FIHA.5360@xxxxxx Quote: > Thanks for the replies, guys. I may do that at some point (reformat) and > reinstall. > > The drivers I care about are M-Audio Audiophile 192 soundcard. Not > available even in beta. I have a souncard that I haven't been able to use > for a year and am using a cheapo that is built in the motherboard. > > I have Vista Ultimate 32 bit on another computer and am using their USB > drivers (just now in beta) with an M-Audio Mobile-Pre soundcard. Also, for > music, is Adobe Audition 3 that's coming out next month. But it will only > be available in Vista 32 bit (per their website). > > I love Vista but to be honest, in using Vista Ultimate 64 bit and 32 bit > on different computers, I can't tell the difference. Except for driver > availability. > > > "cvp" <goaway@xxxxxx> wrote in message > news:euAFkt1FIHA.4584@xxxxxx Quote: >> If true that would be unusual. Care to tell us which drivers are 32-bit >> only? Which soundcards? >> >> Ali Mony wrote: Quote: >>> Is it posssible to install 32 bit Vista over 64 bit? There are so many >>> drivers that I can't get with 64 bit, especially soundcards. After a >>> year I am ready to throw in the towel and go to 32 bit. Thanks. |
| | #7 (permalink) |
| | Re: Dumb down - 64 bit to 32 bit its really for a specific segment of the market that understands the capabilities, advantages and disadvantages of using it, the biggest advantage of all has to be the support for a larger memory address space that allows you to do more number crunching with scientific, financial and other engineering applications that use a lot of memory. Hopefully in the future, more mainstream applications will support the platform and harness its capabilities, but with the majority of systems coming with 1 to 2 GBs of memory, and 64 bit really addressing larger amounts up to 128 GBs, you won't see a lot of apps for now. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Ali Mony" <Jr@xxxxxx> wrote in message news:%23hJ0tJ9FIHA.5360@xxxxxx Quote: > Thanks for the replies, guys. I may do that at some point (reformat) and > reinstall. > > The drivers I care about are M-Audio Audiophile 192 soundcard. Not > available even in beta. I have a souncard that I haven't been able to use > for a year and am using a cheapo that is built in the motherboard. > > I have Vista Ultimate 32 bit on another computer and am using their USB > drivers (just now in beta) with an M-Audio Mobile-Pre soundcard. Also, for > music, is Adobe Audition 3 that's coming out next month. But it will only > be available in Vista 32 bit (per their website). > > I love Vista but to be honest, in using Vista Ultimate 64 bit and 32 bit > on different computers, I can't tell the difference. Except for driver > availability. > > > "cvp" <goaway@xxxxxx> wrote in message > news:euAFkt1FIHA.4584@xxxxxx Quote: >> If true that would be unusual. Care to tell us which drivers are 32-bit >> only? Which soundcards? >> >> Ali Mony wrote: Quote: >>> Is it posssible to install 32 bit Vista over 64 bit? There are so many >>> drivers that I can't get with 64 bit, especially soundcards. After a >>> year I am ready to throw in the towel and go to 32 bit. Thanks. |
| | #8 (permalink) |
| | Re: Dumb down - 64 bit to 32 bit So basically there's no Vista support at all at the moment, with one beta now and one later. It's not surprising that the betas would start off as 32-bit only. Ali Mony wrote: Quote: > Thanks for the replies, guys. I may do that at some point (reformat) and > reinstall. > > The drivers I care about are M-Audio Audiophile 192 soundcard. Not > available even in beta. I have a souncard that I haven't been able to > use for a year and am using a cheapo that is built in the motherboard. > > I have Vista Ultimate 32 bit on another computer and am using their USB > drivers (just now in beta) with an M-Audio Mobile-Pre soundcard. Also, > for music, is Adobe Audition 3 that's coming out next month. But it will > only be available in Vista 32 bit (per their website). > > I love Vista but to be honest, in using Vista Ultimate 64 bit and 32 bit > on different computers, I can't tell the difference. Except for driver > availability. > > > "cvp" <goaway@xxxxxx> wrote in message > news:euAFkt1FIHA.4584@xxxxxx Quote: >> If true that would be unusual. Care to tell us which drivers are >> 32-bit only? Which soundcards? >> >> Ali Mony wrote: Quote: >>> Is it posssible to install 32 bit Vista over 64 bit? There are so >>> many drivers that I can't get with 64 bit, especially soundcards. >>> After a year I am ready to throw in the towel and go to 32 bit. Thanks. |
| Probably a dumb question but... | .NET General | |||
| Why does MS think you are dumb! | Vista General | |||
| Dumb Q2 | Vista General | |||
| Not a bug really, just dumb | Vista General | |||
| Dumb question...RC2 | Vista installation & setup | |||
