Vista - Abit An-7 no sound?
Old 10-27-2007   #1 (permalink)
Len Cuff
Abit An-7 no sound?
Just installed Vista on this mobo but get no sound at all? Downloaded
what I thought were the correct RealTek drivers, device manager shows
it working fine BUT I still don't get any sound at all!!
Anybody got this working?
cheers,
Len
Old 10-27-2007   #2 (permalink)
Richard Urban
Re: Abit An-7 no sound?
Do you mean an A7N motherboard?
Regards,
Richard Urban
"Len Cuff" <len.cuff@xxxxxx> wrote in message
news:qv17i3hsuoimji2oena7cqo1nh21dkbs6e@xxxxxx
> cheers,
> Len
Old 10-27-2007   #3 (permalink)
pvdg42
NVIDIA is not supporting the NForce 2 chipset for Vista. That could be your
problem.
Old 10-27-2007   #4 (permalink)
Len Cuff
On Sat, 27 Oct 2007 18:49:38 GMT, Len Cuff <len.cuff@xxxxxx>
>cheers,
> Len
Well I downloaded the Vista drivers but still nothing UNTIL I tried
moving the connection! Seems I have sound but from one of the other
connections - there are 5 to choose from on this mobo!
cheers,
Len
Old 10-27-2007   #5 (permalink)
Charlie Tame
> problem.
Probably not much of an idea but you have tried all the sockets on the
board for output, I had an Asus MB and one set of drivers had the output
and input sockets the wrong way around
Old 10-27-2007   #6 (permalink)
Charlie Tame
>> cheers,
>> Len
> cheers,
> Len
Ha, so I was a bit late then, oh well, good luck with the rest of the
day experimenting what comes out and goes in where then
Old 10-27-2007   #7 (permalink)
Richard Urban
I have Vista Ultimate installed on two Asus A7N8X 2.0 Deluxe M/B. Works
fairly nice.
Sound is good using the drivers obtained from Windows Update on the first
boot into the desktop. I also had problems with the mini plug connector on
the rear of the M/B. A quick squirt of WD-40 on the plug, and about 5-6
insert/removal cycles solved the problem for me. The connectors become
oxidized and have to be cleaned, especially if the connectors have been
plugged in for a couple of years.
Regards,
Richard Urban
newse57i3dsk9ct1opggs8g4cpefo51gjr5g7@xxxxxx
>>cheers,
>> Len
> cheers,
> Len
Old 10-28-2007   #8 (permalink)
Len Cuff
>cheers,
> Len
Gave up in the end as all I could get was very 'echoy' sound! Slapped
in an old PCI Soundblaster card and it installed and is working fine!
cheers,
Len
Abit Fatal1ty Drivers Drivers
Re: Black screen for abit after boot Vista performance & maintenance
No sound with Realtek ALC850 on Abit AV8 S/PDIF and Vista 32-bit Vista General
Vista on an Abit Fatal1ty AN9 32X Vista installation & setup
abit NI8 SLI unknown device Vista hardware & devices
