| | Re: NIC icon is system tray "Bob" <86c6c2e6-2146512712@xxxxxx> wrote: Quote: > In XP, I could select the properties of my network connection (NIC), and > enable "Show icon in notification area when connected". > > I don't see this option in Vista, yet it seems to display in the system > tray just the same. Is this always enabled now? Or is there a setting > someplace else for it? the Network checkbox is what you're looking for. ThePro |
| | Re: NIC icon is system tray In article <#AkEvNkGIHA.5584@xxxxxx>, mcthepro_@xxxxxx says... Quote: > "Bob" <86c6c2e6-2146512712@xxxxxx> wrote: Quote: > > In XP, I could select the properties of my network connection (NIC), and > > enable "Show icon in notification area when connected". > > > > I don't see this option in Vista, yet it seems to display in the system > > tray just the same. Is this always enabled now? Or is there a setting > > someplace else for it? > Right-click anywhere on the taskbar | Properties | Notification area tab and > the Network checkbox is what you're looking for. On mine, and other computers from posts I've read, turning it off vcan cause the taskbar to occasionally blink on for a split second. Even with the icon, mine does it a little, but without the icon, it does it very often and was very annoying. You may not notice the change until after a reboot. -- If there is a no_junk in my address, please REMOVE it before replying! All junk mail senders will be prosecuted to the fullest extent of the law!! http://home.att.net/~andyross |
| System Tray Icon | Software | |||
| No system tray icon | Live Mail | |||
| RE: NIC icon is system tray | Vista General | |||
| Icon in system tray | Vista mail | |||
| System Tray Icon | Vista security | |||
