RB
Vista - Registry problems
10-29-2007   #1
dudaudio
Registry problems
I am unable to load any programs after a major crash of Vista Home Premium.
Quote:
> The programs load and finish ok (eg Auturoute 2007) but when I try to run them I get told that my registry entries are incorrect and to reload the program again.
> I have tried this and get the same problem.
> Anyone got any ideas?
dudaudio
10-31-2007   #2
Joseph Conway [MSFT]
RE: Registry problems
What do you mean by "major crash in Vista"?
Joseph W. Conway, MCSE
Windows Server Group
10-31-2007   #3
dudaudio
The system just closed down while I was loading a new program with the blue
screen error 0x0000008e.
When I restarted I found that some programs would no longer run, the message
each time was that windows hod found a problem and was going to close the
program. It then crashed with a blue screen and error stop oxoooooo8e.
I tried, located and deleted all of the programs that caused this problem.
I then tried to do a restore but found that the only restore point available
was the one just before the system closed down for the first time. no other
estore points were available.
All other programs that are left still work ok.
dudaudio
11-01-2007   #4
Most likely that was a driver issue then since STOP 0x8E is a kernel mode
exception not handled. The best way to troubleshoot it would be to send us
the dump, but that would require you to open a case.
11-01-2007   #5
dudaudio
How do I open a case?
dudaudio
11-02-2007   #6
http://www.microsoft.com/services/mi...nterprise.mspx
11-02-2007   #7
dudaudio
Thanks for your help Joseph,
But this site seems to be for commercial users, not for a home user like me.
It seems that the only thing I can do is do a clean reload of Vista and hope
for the best.
If it happens again I will probably go back to XP which I found to be very
resiliant.
dudaudio
11-06-2007   #8
Nope, there is a link to consumer support on the right hand side.
11-10-2007   #9
dudaudio
I have had my Vista for over 90 days so rather than spend £50.00 or so for
help I will reload and hope for the best.
I had hoped that someone might have had a suggestion as to why when loading
programs they cannot write to the registry.
Thanks for your suggstion.
dudaudio
11-16-2007   #10
Re: Registry problems
It's often due to an antivirus program. Which if any such programs do
you have?
"dudaudio" <dudaudio@xxxxxx> wrote in message
news:22622D77-3621-4E60-A7C2-02F8EADEA71E@xxxxxx
> loading
> dudaudio
>> rights.
RB
Similar Threads for: Registry problems
Registry Problems? Vista General
Windows registry problems General Discussion
CD ROM / Registry problems Vista performance & maintenance
Registry Problems Vista General
registry problems in RC2.... Vista installation & setup
