| | driver for USB to DB25 female cable I'm trying to hook up my old HP Laserjet 1100 with my new HP desktop. I bought the USB to DB25 female cable so I could hook up the old printer since my desktop only has USB inputs. I can't get it to work though. No luck printing. The PC recognizes that I've hooked up a new device, confirms I have the driver for it, but can't get it to print. Running Vista. Are there specific drivers I can download to get this cable to work? |
| | Re: driver for USB to DB25 female cable What notice sometimes is with some USB based scanners and printers, especially from HP, you have to install the device driver first before connecting, restart then connect the device and will showup or start working. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry <bluff@xxxxxx> wrote in message news:1193708081.310250.205790@xxxxxx Quote: > I'm trying to hook up my old HP Laserjet 1100 with my new HP desktop. > I bought the USB to DB25 female cable so I could hook up the old > printer since my desktop only has USB inputs. I can't get it to work > though. No luck printing. The PC recognizes that I've hooked up a > new device, confirms I have the driver for it, but can't get it to > print. > > Running Vista. Are there specific drivers I can download to get this > cable to work? > |
| | Re: driver for USB to DB25 female cable This may be a really wild shot, but I could not get my HP1200 printer to work with Remote Desktop using the USB. It may be a redirect problem since it is using a USB port. I don't know if it will help or not, but you might review this link http://support.microsoft.com/kb/302361 It solved my print with RD. <bluff@xxxxxx> wrote in message news:1193708081.310250.205790@xxxxxx Quote: > I'm trying to hook up my old HP Laserjet 1100 with my new HP desktop. > I bought the USB to DB25 female cable so I could hook up the old > printer since my desktop only has USB inputs. I can't get it to work > though. No luck printing. The PC recognizes that I've hooked up a > new device, confirms I have the driver for it, but can't get it to > print. > > Running Vista. Are there specific drivers I can download to get this > cable to work? > |
| Hopeless female needs some vista help | Vista General | |||
| setting up cable TV: WMC can't detect cable signal | Vista General | |||
| Nokia CA-42 Cable Driver | Drivers | |||
| DKU-5 nokia cable driver problem | Vista hardware & devices | |||
| easy transfer cable driver issue | Vista General | |||
