Vista - Problem Deleting Files
Old 11-05-2007   #11 (permalink)
jola57
Re: Problem Deleting Files
it is not cs3 its from 2005 so cs2. do you have a solution for cs2?
"jim" wrote:
Quote:
> Did you try the manual method listed at
> http://kb.adobe.com/selfservice/view...nalId=kb401501 ?
> jim
> "jola57" <jola57@xxxxxx> wrote in message
> news:21D80C84-6B41-4806-B654-1A5329321CB4@xxxxxx
Quote:
> >I have the same problem with deleting photoshop form production suite.
> >after
> > 5 hours with adobe tech i am still not able to install my full production
> > studio. i run msicuu2 and wincs3clean. didn't work. any other
> > suggestions.
> > i need to work with the production studio - it has been now 3 days on the
> > phone with techs.
> > "jim" wrote:
Quote:
> >> I wonder if this helped?
> >> "jim" <jim@xxxxxx> wrote in message
> >> news:BtTWi.48698$b9.27281@xxxxxx
> >> > http://www.adobe.com/support/contact/cs3clean.html
> >> > news:rQOWi.1356$di.1254@xxxxxx
> >> >> Adobe CS3Clean Script
> >> >> The Adobe CS3Clean Script will help resolve installation problems
> >> >> experienced by users of Adobe Creative Suite software. The script will
> >> >> clean up any beta and pre-release installations. It will also look for
> >> >> and repair registry permissions and remove obsolete registry entries
> >> >> of
> >> >> older Flash Player versions, to ensure successful installation of the
> >> >> shipping versions of Creative Suite 3.
> >> >> 1.. Back-up all data prior to using the CS3Clean Script. This
> >> >> includes
> >> >> fonts, Version Cue repositories, plugins and any other important
> >> >> files.
> >> >> 2.. Uninstall your beta or pre-release Creative Suite 3 prior to
> >> >> using
> >> >> a.. On Windows XP, uninstall via Add/Remove Programs in the Control
> >> >> Panel.
> >> >> b.. On Windows Vista, in the Programs section of the Control Panel,
> >> >> select Uninstall a Program.
> >> >> c.. On Macintosh, the uninstaller is in
> >> >> Applications/Utilities/Adobe
> >> >> Installers.
> >> >> 3.. Download the appropriate file from below.
> >> >> 4.. Unpack the download. The download includes the script as well as
> >> >> additional system-specific instructions.
> >> >> 5.. Open and follow the instructions for assistance installing the
> >> >> script.
> >> >> 6.. Once the script has successfully completed, continue with your
> >> >> installation of the shipping version of Creative Suite 3.
> >> >> Download
> >> >> It is important you read and carefully follow the instructions
> >> >> included
> >> >> with the download.
> >> >> English/Japanese
> >> >> a.. Download the Adobe CS3Clean Script for Windows (ZIP, 978 KB)
> >> >> jim
> >> >> Bill Gates lives in constant fear that Chuck Norris' PC will crash.
> >> >> "Linda" <linda@xxxxxx> wrote in message
> >> >> news:B9FCB728-24EB-4B0B-8C95-5CA181139169@xxxxxx
> >> >>> System restore seems to be what got me into my predicament in the
> >> >>> first
> >> >>> place
> >> >>> - it seems to have left a subset of the Adobe files installed files
> >> >>> on
> >> >>> the
> >> >>> system. Either that or the CS3 install package installed some files
> >> >>> before
> >> >>> erroring out when I attempted the reinstall. In any case, Adobe says
> >> >>> the CS3
> >> >>> installer won't work unless the system is free of all Adobe files.
> >> >>> So,
> >> >>> my
> >> >>> first problem to solve is getting rid of the Adobe files that are on
> >> >>> my
> >> >>> system. Is it safe to run the Adobe uninstall script and Windows
> >> >>> cleanup
> >> >>> utility in diagnostics mode? I don't have any program listing in CS3
> >> >>> in
> >> >>> the
> >> >>> Control Panel program list any more. Any other suggestions?
> >> >>> Linda
> >> >>> "Linda" wrote:
> >> >>>> After installing Adobe's Creative Suite 3, I lost Control Panel and
> >> >>>> had
> >> >>>> to do
> >> >>>> a system restore back to a point before the install. I'm now having
> >> >>>> difficulty reinstalling CS3. Adobe tech support tells me I need to
> >> >>>> remove any
> >> >>>> remaining files before trying the reinstall. My problem is that I've
> >> >>>> already
> >> >>>> removed the program using the normal uninstall, run Adobe's
> >> >>>> uninstall
> >> >>>> scripts
> >> >>>> which also uses the WIndows clean-up utiltiy, tried to remove
> >> >>>> straglers
> >> >>>> byaltering permissions on file properties. I've been able to remove
> >> >>>> all
> >> >>>> but
> >> >>>> the following files and folders:
> >> >>>> Adobe\
> >> >>>> Adobe\Acrobat 8.0\
> >> >>>> Adobe\Acrobat 8.0\acrotray
> >> >>>> Adobe\Acrobat 8.0\adistres.dll
> >> >>>> Adobe\Acrobat Elements\
> >> >>>> Adobe\Acrobat Elements\ContextMenu.dll
> >> >>>> CommonFiles\Adobe\
> >> >>>> CommonFiles\Adobe\Acrobat\ActiveX\
> >> >>>> CommonFiles\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
> >> >>>> CommonFiles\Adobe\Acrobat\ActiveX\AcroPDF
> >> >>>> CommonFiles\Adobe\Acrobat\ActiveX\pdfshell
> >> >>>> I'm guessing these files/folders must be corrupt. The system tells
> >> >>>> me I
> >> >>>> don't have permission to delete but I have full administrator access
> >> >>>> on
> >> >>>> some
> >> >>>> of the files and on others I am unable to change the permissions.
> >> >>>> Does
> >> >>>> anyone
> >> >>>> have any ideas on how I can delete these? I have a fairly new Sony
> >> >>>> laptop
> >> >>>> with Vista Home Premium and don't really want to take my machine
> >> >>>> back
> >> >>>> to a
> >> >>>> full recovery. Any advice? Is it worth the cost of calling Microsoft
> >> >>>> support?
> >> >>>> Thanks,
> >> >>>> Linda
Old 11-06-2007   #12 (permalink)
jim
http://www.google.com/search?q=manua...x=&startPage=1
Google....try it sometime.
jim
news30DF540-EB0C-4105-BE38-004278041B57@xxxxxx
>> jim
>> >after
>> > production
>> > suggestions.
>> > the
>> > phone with techs.
>> >> >> will
>> >> >> for
>> >> >> entries
>> >> >> of
>> >> >> the
>> >> >> includes
>> >> >> files.
>> >> >> using
>> >> >> Control
>> >> >> Panel.
>> >> >> Panel,
>> >> >> Installers.
>> >> >> as
>> >> >> script.
>> >> >> Download
>> >> >> included
>> >> >> with the download.
>> >> >> English/Japanese
>> >> >> jim
>> >> >>> first
>> >> >>> place
>> >> >>> files
>> >> >>> on
>> >> >>> the
>> >> >>> files
>> >> >>> before
>> >> >>> says
>> >> >>> the CS3
>> >> >>> So,
>> >> >>> my
>> >> >>> on
>> >> >>> my
>> >> >>> cleanup
>> >> >>> CS3
>> >> >>> in
>> >> >>> the
>> >> >>> Linda
>> >> >>>> and
>> >> >>>> had
>> >> >>>> to do
>> >> >>>> having
>> >> >>>> to
>> >> >>>> remove any
>> >> >>>> I've
>> >> >>>> already
>> >> >>>> uninstall
>> >> >>>> scripts
>> >> >>>> straglers
>> >> >>>> remove
>> >> >>>> all
>> >> >>>> but
>> >> >>>> Adobe\
>> >> >>>> Adobe\Acrobat 8.0\
>> >> >>>> CommonFiles\Adobe\
>> >> >>>> tells
>> >> >>>> me I
>> >> >>>> access
>> >> >>>> on
>> >> >>>> some
>> >> >>>> Does
>> >> >>>> anyone
>> >> >>>> Sony
>> >> >>>> laptop
>> >> >>>> back
>> >> >>>> to a
>> >> >>>> Microsoft
>> >> >>>> support?
>> >> >>>> Thanks,
>> >> >>>> Linda
problem uninstalling / deleting files/folders Vista General
Problem deleting movie files Vista music pictures video
Deleting System files problem Vista General
Problem with Vista deleting, modifying files on an XP drive Vista General
Another Deleting Files Problem... Vista account administration
