Vista - Problem Deleting Files
Old 11-01-2007   #1 (permalink)
Linda
After installing Adobe's Creative Suite 3, I lost Control Panel and had to do
a system restore back to a point before the install. I'm now having
difficulty reinstalling CS3. Adobe tech support tells me I need to remove any
remaining files before trying the reinstall. My problem is that I've already
removed the program using the normal uninstall, run Adobe's uninstall scripts
which also uses the WIndows clean-up utiltiy, tried to remove straglers
byaltering permissions on file properties. I've been able to remove all but
the following files and folders:
Adobe\
Adobe\Acrobat 8.0\
Adobe\Acrobat 8.0\acrotray
Adobe\Acrobat 8.0\adistres.dll
Adobe\Acrobat Elements\
Adobe\Acrobat Elements\ContextMenu.dll
CommonFiles\Adobe\
CommonFiles\Adobe\Acrobat\ActiveX\
CommonFiles\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
CommonFiles\Adobe\Acrobat\ActiveX\AcroPDF
CommonFiles\Adobe\Acrobat\ActiveX\pdfshell
I'm guessing these files/folders must be corrupt. The system tells me I
don't have permission to delete but I have full administrator access on some
of the files and on others I am unable to change the permissions. Does anyone
have any ideas on how I can delete these? I have a fairly new Sony laptop
with Vista Home Premium and don't really want to take my machine back to a
full recovery. Any advice? Is it worth the cost of calling Microsoft support?
Thanks,
Linda
Old 11-01-2007   #2 (permalink)
jim
Re: Problem Deleting Files
Have you simply tried using Vista's system restore?
jim
Bill Gates lives in constant fear that Chuck Norris' PC will crash.
"Linda" <linda@xxxxxx> wrote in message
news:9A55A4DC-9151-40E1-B8E6-9BA5B7144953@xxxxxx
> do
> any
> already
> scripts
> but
> Adobe\
> Adobe\Acrobat 8.0\
> CommonFiles\Adobe\
> some
> anyone
> support?
> Thanks,
> Linda
Old 11-01-2007   #3 (permalink)
Andre Da Costa[ActiveWin]
I have personally found the best way to remove certain applications is
through Diagnostics Mode. Open MSCONFIG > (Win + R) > General (tab) >
Diagnostics Startup > click OK. Click Restart when the prompt appears. When
you are in Diagnostics mode, try uninstalling again. But in this case, you
have already uninstalled, so I would reinstall the application then follow
my suggested instructions.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
> do
> any
> already
> scripts
> but
> Adobe\
> Adobe\Acrobat 8.0\
> CommonFiles\Adobe\
> some
> anyone
> support?
> Thanks,
> Linda
Old 11-02-2007   #4 (permalink)
Linda
RE: Problem Deleting Files
System restore seems to be what got me into my predicament in the first place
- it seems to have left a subset of the Adobe files installed files on the
system. Either that or the CS3 install package installed some files before
erroring out when I attempted the reinstall. In any case, Adobe says the CS3
installer won't work unless the system is free of all Adobe files. So, my
first problem to solve is getting rid of the Adobe files that are on my
system. Is it safe to run the Adobe uninstall script and Windows cleanup
utility in diagnostics mode? I don't have any program listing in CS3 in the
Control Panel program list any more. Any other suggestions?
Linda
> Adobe\
> Adobe\Acrobat 8.0\
> CommonFiles\Adobe\
> Thanks,
> Linda
Old 11-02-2007   #5 (permalink)
jim
Adobe CS3Clean Script
The Adobe CS3Clean Script will help resolve installation problems
experienced by users of Adobe Creative Suite software. The script will clean
up any beta and pre-release installations. It will also look for and repair
registry permissions and remove obsolete registry entries of older Flash
Player versions, to ensure successful installation of the shipping versions
of Creative Suite 3.
1.. Back-up all data prior to using the CS3Clean Script. This includes
fonts, Version Cue repositories, plugins and any other important files.
2.. Uninstall your beta or pre-release Creative Suite 3 prior to using the
CS3Clean Script.
a.. On Windows XP, uninstall via Add/Remove Programs in the Control
Panel.
b.. On Windows Vista, in the Programs section of the Control Panel,
select Uninstall a Program.
c.. On Macintosh, the uninstaller is in Applications/Utilities/Adobe
Installers.
3.. Download the appropriate file from below.
4.. Unpack the download. The download includes the script as well as
additional system-specific instructions.
5.. Open and follow the instructions for assistance installing the script.
6.. Once the script has successfully completed, continue with your
installation of the shipping version of Creative Suite 3.
Download
It is important you read and carefully follow the instructions included with
the download.
English/Japanese
a.. Download the Adobe CS3Clean Script for Windows (ZIP, 978 KB)
jim
news:B9FCB728-24EB-4B0B-8C95-5CA181139169@xxxxxx
> place
> CS3
> the
> Linda
> "Linda" wrote:
>> to do
>> any
>> already
>> scripts
>> but
>> Adobe\
>> Adobe\Acrobat 8.0\
>> CommonFiles\Adobe\
>> some
>> anyone
>> a
>> support?
>> Thanks,
>> Linda
Old 11-03-2007   #6 (permalink)
jim
http://www.adobe.com/support/contact/cs3clean.html
"jim" <jim@xxxxxx> wrote in message
news:rQOWi.1356$di.1254@xxxxxx
> clean up any beta and pre-release installations. It will also look for and
> repair registry permissions and remove obsolete registry entries of older
> Flash Player versions, to ensure successful installation of the shipping
> versions of Creative Suite 3.
> Panel.
> Installers.
> script.
> Download
> with the download.
> English/Japanese
> jim
>> place
>> the
>> before
>> CS3
>> the
>> Linda
>> "Linda" wrote:
>>> to do
>>> remove any
>>> already
>>> scripts
>>> but
>>> Adobe\
>>> Adobe\Acrobat 8.0\
>>> CommonFiles\Adobe\
>>> some
>>> anyone
>>> laptop
>>> a
>>> support?
>>> Thanks,
>>> Linda
Old 11-03-2007   #7 (permalink)
jim
I wonder if this helped?
news:BtTWi.48698$b9.27281@xxxxxx
>> and repair registry permissions and remove obsolete registry entries of
>> older Flash Player versions, to ensure successful installation of the
>> shipping versions of Creative Suite 3.
>> Panel.
>> Installers.
>> script.
>> Download
>> with the download.
>> English/Japanese
>> jim
>>> place
>>> the
>>> before
>>> the CS3
>>> my
>>> the
>>> Linda
>>>> to do
>>>> remove any
>>>> already
>>>> scripts
>>>> but
>>>> Adobe\
>>>> Adobe\Acrobat 8.0\
>>>> CommonFiles\Adobe\
>>>> some
>>>> anyone
>>>> laptop
>>>> to a
>>>> support?
>>>> Thanks,
>>>> Linda
Old 11-03-2007   #8 (permalink)
uvbogden
Vista uninstaller does a very poor job of removing all parts of a program.
Sometimes the proprietary removal tool can help, you can do a manual
uninstall, but the best way to get rid of all remnants of a program, failed
download and install, or failed uninstall is using Smarty Uninstaller. Until
you clean your system of this debris, you won't be able to install the new
program. You can access Smarty Uninstaller and how-to manual uninstall at
the tutorial link below.
To assist with a manual uninstall as far as being able to modify (copy,
delete, rename) you can take Ownership of (in your Username) and grant
yourself Full Control permissions of the files or folders in question
described in the following tutorial. Another way to gain access to modify
files and folders includes going to the Start button, typing in Windows
Explorer, right-clicking on this and selecting Run As Administrator. You
should then have "elevated privileges" to do whatever you wish to files in
Windows Explorer. There is also a program called Unlocker that you can use
to gain access to modify files and folders (see link below).
Unable To Install Latest Version of Program on Vista
Take Ownership of file
http://ccollomb.free.fr/unlocker/
> >> Panel.
> >> Installers.
> >> script.
> >> Download
> >> with the download.
> >> English/Japanese
> >> jim
> >>> place
> >>> the
> >>> before
> >>> the CS3
> >>> my
> >>> the
> >>> Linda
> >>>> to do
> >>>> remove any
> >>>> already
> >>>> scripts
> >>>> but
> >>>> Adobe\
> >>>> Adobe\Acrobat 8.0\
> >>>> CommonFiles\Adobe\
> >>>> some
> >>>> anyone
> >>>> laptop
> >>>> to a
> >>>> support?
> >>>> Thanks,
> >>>> Linda
Old 11-03-2007   #9 (permalink)
jola57
I have the same problem with deleting photoshop form production suite. after
5 hours with adobe tech i am still not able to install my full production
studio. i run msicuu2 and wincs3clean. didn't work. any other suggestions.
i need to work with the production studio - it has been now 3 days on the
phone with techs.
> >> Panel.
> >> Installers.
> >> script.
> >> Download
> >> with the download.
> >> English/Japanese
> >> jim
> >>> place
> >>> the
> >>> before
> >>> the CS3
> >>> my
> >>> the
> >>> Linda
> >>>> to do
> >>>> remove any
> >>>> already
> >>>> scripts
> >>>> but
> >>>> Adobe\
> >>>> Adobe\Acrobat 8.0\
> >>>> CommonFiles\Adobe\
> >>>> some
> >>>> anyone
> >>>> laptop
> >>>> to a
> >>>> support?
> >>>> Thanks,
> >>>> Linda
Old 11-04-2007   #10 (permalink)
jim
Did you try the manual method listed at
http://kb.adobe.com/selfservice/view...nalId=kb401501 ?
jim
"jola57" <jola57@xxxxxx> wrote in message
news:21D80C84-6B41-4806-B654-1A5329321CB4@xxxxxx
>after
> suggestions.
> phone with techs.
>> >> of
>> >> includes
>> >> files.
>> >> using
>> >> Panel.
>> >> Installers.
>> >> script.
>> >> Download
>> >> included
>> >> with the download.
>> >> English/Japanese
>> >> jim
>> >>> first
>> >>> place
>> >>> on
>> >>> the
>> >>> before
>> >>> the CS3
>> >>> So,
>> >>> my
>> >>> my
>> >>> cleanup
>> >>> in
>> >>> the
>> >>> Linda
>> >>>> had
>> >>>> to do
>> >>>> remove any
>> >>>> already
>> >>>> uninstall
>> >>>> scripts
>> >>>> straglers
>> >>>> all
>> >>>> but
>> >>>> Adobe\
>> >>>> Adobe\Acrobat 8.0\
>> >>>> CommonFiles\Adobe\
>> >>>> me I
>> >>>> on
>> >>>> some
>> >>>> Does
>> >>>> anyone
>> >>>> laptop
>> >>>> back
>> >>>> to a
>> >>>> support?
>> >>>> Thanks,
>> >>>> Linda
problem uninstalling / deleting files/folders Vista General
Problem deleting movie files Vista music pictures video
Deleting System files problem Vista General
Problem with Vista deleting, modifying files on an XP drive Vista General
Another Deleting Files Problem... Vista account administration
