Vista - Drive letter assignment
Old 11-02-2007   #1 (permalink)
smudgers2
Can anyone help? reinstalled vista after getting rid of dual boot with xp and
reformatting hard drive. For some reason vista's allocated drive letter I
instead of C to the boot Drive and drive C to my data Drive. Changed data
drive to D in disk management, but wont allow me to change I to C because
boot drive. Can I correct this with out having to reformat and re-install?
smudgers2
Old 11-02-2007   #2 (permalink)
Rick Rogers
Re: Drive letter assignment
You cannot change drive letters assigned to designated system or boot
volumes without starting from scratch or until that volume no longer has one
of those designations. If Vista is installed to C: and you move the system
designation from I: to C:, you will then be able to to reletter that volume.
To do so, you would need to work from the recovery environment after
changing the active partition in disk management.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"smudgers2" <smudgers2@xxxxxx> wrote in message
news:B4F40FF8-2E90-432B-9E5B-603D867A937B@xxxxxx
> and
> smudgers2
Change floppy drive assignment from B: to A: Vista hardware & devices
Flash Drive has no drive letter... Not in Disk Management Vista hardware & devices
Phantom CD Drive after reassigning Recovery Partition drive letter Vista installation & setup
Restoring flexible drive letter assignment Vista hardware & devices
LastWriteTime and Locating the drive letter of a flash drive. PowerShell
