Readyboost does not start
  1. #1
    matslingblad Guest
    I bought a 2GB fast USB drive to use READYBOOST in Vista. Often it
    doesn't seem to connect automatically after I've shut down Windows.
    This is happinging right now and I check Properties tab ReadyBoost. I
    get the message that I need at least 235 MB to enable Readyboost. I
    then check in explorer and I only see a few small exe files. I have
    ticked so I show hidden and protcted files. Basically, there is a huge
    file somewhere on the USB drive that was used for ReadyBoost last
    time. Now neither ReadyBoost nor Explorer can access this file.
    Anyone has encountered this problwem and have a solution?
  2. #2
    Andre Da Costa[ActiveWin] Guest
    Re: Readyboost does not start
    Try disabling and re-enabling ReadyBoost then reconnect your device. If that
    does not work, format the device and try again. Also, to be sure the device
    is working properly, try another thumb drive just make sure its not a
    defect.
    Click on the Start button.
    Click on the Control Panel menu option.
    Click on Performance Information and Tools
    Click on Advanced Tools in the left hand navigation bar.
    Click on Configure my Windows ReadyBoost device
    You will now be back at the Windows ReadyBoost Properties. To disable
    ReadyBoost simply select the option that is labeled Do not use this device.
    Andre
    Blog: http://adacosta.spaces.live.com
    My Vista Quickstart Guide:
    http://adacosta.spaces.live.com/blog...3DB!9709.entry
    <matslingblad@xxxxxx> wrote in message
    news:1194006441.301996.35260@xxxxxx
  3. #3
    flambe Guest
    While I understand the obsession to get Readyboost to work because it is
    supposed to the fact is, considering the multiple independent reviews and
    tests done on the subject, that Readyboost does nothing to speed up your
    computer any may actually slow it down from Vista's usual snail's pace.
    Good luck.
  4. #4
    rtk Guest
    Care to point out one of these independent reviews? Specifically one that
    isn't hoping to gain frames per second in a first person shooter.
    Sounds to me like you don't have a clue what Readyboost is.
    rtk
    "flambe" <fac187@xxxxxx> wrote in message
    news:eUGWi.13229$4V6.1782@xxxxxx
    > Good luck.
  5. #5
    matslingblad Guest
    Yes it works by reformatting the USB drive. Is there no other way to
    get it to work???
    Yes it doesn't seem to do much in terms of speed, but when I'm using
    Photoshop at least there is high read/write action. I havn't read
    anywhere that it slows down the computer. Any reference on that?
Readyboost does not start problems?
ReadyBoost Brink Tutorials 20 06 Jul 2010
Readyboost Help D4v15 Vista performance & maintenance 0 01 Feb 2009
readyboost Traveller© Vista General 7 25 Sep 2008
ReadyBoost - how to set up PERFMON to monitor ReadyBoost activity Fred B. Vista General 3 01 Sep 2007
ReadyBoost Master P Vista hardware & devices 2 21 May 2007
