Problem Reports and Solutions KB
  1. #1
    Clayton Guest
    I've got this message saying the following about KB938979. So I downloaded
    the patch to find it is already installed
    And idea's on what is going on here?
    Technical Information
    Performance and Reliability Pack (KB938979)
    Follow these steps to solve the problem with Windows Vista
    This problem was caused by Windows Vista, which was created by
    Microsoft Corporation.
    A solution is available that will solve this problem.
    Solution
    To view details about how to fix this problem, click the link under
    Technical information. This link will take you to a Microsoft Support
    Knowledge Base (KB) article. Follow the steps in the article to fix your
    computer problem.
    About Microsoft Knowledge Base articles
    Some Knowledge Base articles are written for users who are comfortable
    with advanced troubleshooting. If you are not an advanced user and find this
    article a bit difficult to use, you might want to ask a professional
    computer technician to help you solve this problem.
    Rate this response:Provide Feedback
  2. #2
    Kue2 Guest
    Re: Problem Reports and Solutions KB
    Sometimes there is a fix for 32 vista & 64 vista
    Did you make sure you d/led the right one?
    "Clayton" <claytonbNOSPAM@xxxxxx> wrote in message
    news:uwotgcXHIHA.4808@xxxxxx
    > Solution
    > computer problem.
    > comfortable
    > this
  3. #3
    Andre Da Costa[ActiveWin] Guest
    But the question is, where did you get the information? Please note, you can
    get KB Patches through Microsoft Download Center, which website normally
    post links to for persons who might be unable in someway to download through
    Windows Update.
    Andre
    Blog: http://adacosta.spaces.live.com
    My Vista Quickstart Guide:
    http://adacosta.spaces.live.com/blog...3DB!9709.entry
    > Solution
    > computer problem.
    > comfortable
    > this
  4. #4
    Kue2 Guest
    I think he got it from solving problems & solution in Vista
    "Andre Da Costa[ActiveWin]" <andred25@xxxxxx> wrote in message
    news:uQjgqmXHIHA.5276@xxxxxx
    > can get KB Patches through Microsoft Download Center, which website
    > normally post links to for persons who might be unable in someway to
    > download through Windows Update.
    > Andre
    >> downloaded
    >> Solution
    >> computer problem.
    >> comfortable
    >> this
  5. #5
    Oops Still, even if its suggested by it, it doesn't necessarily mean it
    needs to be installed again, since that has been done already. The fact that
    its already installed, the Problem Reports and Solutions should just be
    ignored.
    Andre
    "Kue2" <h.j.kennedy@xxxxxx> wrote in message
    news:ul9C5wXHIHA.5544@xxxxxx
    >> Andre
    >>> downloaded
    >>> Solution
    >>> computer problem.
    >>> comfortable
    >>> this
  6. #6
    Kue2 Guest
    Maybe there is a version 2 of that KB update.
    news:%23pBYH1XHIHA.3940@xxxxxx
    > that its already installed, the Problem Reports and Solutions should just
    > be ignored.
    > Andre
    >>> Andre
    >>>> downloaded
    >>>> Solution
    >>>> under
    >>>> your
    >>>> computer problem.
    >>>> comfortable
    >>>> this
  7. #7
    Clayton Guest
    I'll ignore it, it's only happenned to me once, if it happens to many times
    I'll report back
    cheers
    news:eUIqgCYHIHA.4196@xxxxxx
    >> it needs to be installed again, since that has been done already. The
    >> fact that its already installed, the Problem Reports and Solutions should
    >> just be ignored.
    >> Andre
    >>>> you can get KB Patches through Microsoft Download Center, which website
    >>>> Andre
    >>>>> downloaded
    >>>>> Solution
    >>>>> under
    >>>>> your
    >>>>> computer problem.
    >>>>> comfortable
    >>>>> find this
  8. #8
    Laura Bales Guest
    PLEASE HELP ME!!! Re: Problem Reports and Solutions KB
    My name is Laura and this PROBLEM is Happening to ME ALL THE TIME. However,
    When I try to download the update, MS Downloads tells me that this update
    doesn't apply to my system....
    Can Anyone Help Me???
    > I'll report back
    > cheers
    > >> just be ignored.
    > >> Andre
    > >>>> Andre
    > >>>>> downloaded
    > >>>>> Solution
    > >>>>> under
    > >>>>> your
    > >>>>> computer problem.
    > >>>>> comfortable
    > >>>>> find this
Problem Reports and Solutions KB problems?
Problem Reports and Solutions.....? Dirty Dawg Vista performance & maintenance 1 24 Jul 2008
Problem Reports and Solutions GillB Vista General 3 18 Jul 2008
problem reports and solutions lady eliza Vista performance & maintenance 3 25 Mar 2008
Problem Reports and Solutions mimihen Vista General 0 01 Feb 2008
problem reports and solutions rwolcott1 Vista General 0 26 Jul 2007
