| Guest | Autoplay Does Not Work Hi, I'm running Vista Home Premium. I properly set the AutoPlay defaults for CDs and DVDs, yet neither disc type plays when inserted. I have to start them manually . I got some troubleshoot advice elsewhere: Click the start button, click all programs, click accessories, then right-click command prompt. I tried this, but there was no command prompt. Any help will be appreciated. Morton Linder |
| Guest | Re: Autoplay Does Not Work Copy the below information to a .txt file: ******************************************* Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer] "NoDriveTypeAutoRun"=dword:00000095 ******************************************* Save the file as Autoplay.reg Double click to run the file. Accept the addition to the registry. Reboot. Put in the Audio CD or Movie DVD and watch it start correctly. -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) "Morton" <mort@xxxxxx> wrote in message news:dpPWi.458$p37.358@xxxxxx Quote: > Hi, > > I'm running Vista Home Premium. I properly set the AutoPlay defaults for > CDs and DVDs, yet neither disc type plays when inserted. I have to start > them manually . > > I got some troubleshoot advice elsewhere: > Click the start button, click all programs, click accessories, then > right-click command prompt. I tried this, but there was no command prompt. > > Any help will be appreciated. > > Morton Linder |
| Guest | Re: Autoplay Does Not Work Richard Urban wrote: Quote: > Copy the below information to a .txt file: > > ******************************************* > > Windows Registry Editor Version 5.00 > > [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer] > > "NoDriveTypeAutoRun"=dword:00000095 > > ******************************************* > > Save the file as Autoplay.reg > > Double click to run the file. Accept the addition to the registry. > > Reboot. Put in the Audio CD or Movie DVD and watch it start correctly. > > > Thanks a lot for your reply. I do not know how to start a .txt file, and my Vista books have not been any help. In my 10 years with PCs, I've never had to start a new file thusly. Can you please explain how I should do it, or refer me to a turorial that explains it. Thanks again. Morton |
| Guest | Re: Autoplay Does Not Work "Morton" <mort@xxxxxx> wrote in message news:1e8Yi.35$p17.19@xxxxxx Quote: > Richard Urban wrote: Quote: >> Copy the below information to a .txt file: >> >> ******************************************* >> >> Windows Registry Editor Version 5.00 >> >> [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer] >> "NoDriveTypeAutoRun"=dword:00000095 >> >> ******************************************* >> >> Save the file as Autoplay.reg >> >> Double click to run the file. Accept the addition to the registry. >> >> Reboot. Put in the Audio CD or Movie DVD and watch it start correctly. >> >> >> > > Thanks a lot for your reply. I do not know how to start a .txt file, and my Vista books have not been any > help. In my 10 years with PCs, I've never had to start a new file thusly. Can you please explain how I > should do it, or refer me to a turorial that explains it. > > Thanks again. > > Morton -- Steve Easton |
| Guest | Re: Autoplay Does Not Work Steve Easton wrote: Quote: > "Morton" <mort@xxxxxx> wrote in message news:1e8Yi.35$p17.19@xxxxxx Quote: >> Richard Urban wrote: Quote: >>> Copy the below information to a .txt file: >>> >>> ******************************************* >>> >>> Windows Registry Editor Version 5.00 >>> >>> [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer] >>> "NoDriveTypeAutoRun"=dword:00000095 >>> >>> ******************************************* >>> >>> Save the file as Autoplay.reg >>> >>> Double click to run the file. Accept the addition to the registry. >>> >>> Reboot. Put in the Audio CD or Movie DVD and watch it start correctly. >>> >>> >>> >> >> Thanks a lot for your reply. I do not know how to start a .txt file, and my Vista books have not been any >> help. In my 10 years with PCs, I've never had to start a new file thusly. Can you please explain how I >> should do it, or refer me to a turorial that explains it. >> >> Thanks again. >> >> Morton > Open Notepad. > didn't know how. Much obliged. Mort |
| | #6 (permalink) |
| Guest | Re: Autoplay Does Not Work Highlight, and then copy, the information between the lines of asterisks. Go to Start | All Programs | Accessories Open Notepad Right click anywhere in the white area and choose "paste". Save the file using "save as" autoplay.reg (note where you save the file to) Close notepad Go to where you saved the file. Double click the file to run it. -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) "Morton" <mort@xxxxxx> wrote in message news:9MaYi.869$o41.88@xxxxxx Quote: > Steve Easton wrote: Quote: >> "Morton" <mort@xxxxxx> wrote in message >> news:1e8Yi.35$p17.19@xxxxxx Quote: >>> Richard Urban wrote: >>>> Copy the below information to a .txt file: >>>> >>>> ******************************************* >>>> >>>> Windows Registry Editor Version 5.00 >>>> >>>> [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer] >>>> "NoDriveTypeAutoRun"=dword:00000095 >>>> >>>> ******************************************* >>>> >>>> Save the file as Autoplay.reg >>>> >>>> Double click to run the file. Accept the addition to the registry. >>>> >>>> Reboot. Put in the Audio CD or Movie DVD and watch it start correctly. >>>> >>>> >>>> >>> Hi Richard, >>> >>> Thanks a lot for your reply. I do not know how to start a .txt file, >>> and my Vista books have not been any help. In my 10 years with PCs, I've >>> never had to start a new file thusly. Can you please explain how I >>> should do it, or refer me to a turorial that explains it. >>> >>> Thanks again. >>> >>> Morton >> Open Notepad. >> > didn't know how. > Much obliged. > Mort |
| Autoplay Doesn't Work | Vista General | |||
| Autoplay doesn't work | General Discussion | |||
| Camera Autoplay doesn't work | Vista General | |||
| AutoPlay Does Not Work With CDs or DVDs | Vista General | |||
| AutoPlay Doesn't Work? | Vista General | |||
