| | Vista - Problem mapping Documents to network drive |
| 11-03-2007 | #1 (permalink) |
| | Problem mapping Documents to network drive Hi, I've just got a new PC running Vista. Previously had my "My Documents" running on a network share as I accessed it from my laptop and my desktop at different times. I also have a backup system running off the share. Now, I've been able to move the location of the Documents folder via the locations tab to point to the network share. That all worked fine. "My Documents" appears as a yellow folder in my personalised folder access area that has my user name. Also the "Documents" link on the panel that appears when you click the "Start" button as it used to be called has changed to be called "My Documents" and takes me to the network share. However, when I reboot the network connection is not reestablished. I have to go and login to the network share again manually. This is despite the fact that I keep telling Vista to remember the password. Also, when I do go and relogin to this network share there is then a lag before the My Documents folder reappears in my "home" directory and a further lag again before the "Documents" link on the start panel changes to "My Documents". In the meantime clicking on that "Documents" link does nothing. What can I do to have everything retore how I want it on start up? Thanks |
| My System Specs |
| 11-03-2007 | #2 (permalink) |
| | Re: Problem mapping Documents to network drive Dear Dave, Did you try adding EnableLinkedConnections to your Windows registry? Please see http://www.pctipsbox.com/enabled-lin...ons-for-vista/ for details. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies \System EnableLinkedConnections = 1 (DWord) Regards, Murphy On 11 4 , 12 31 , DaveW1964 <DaveW1...@xxxxxx> wrote: Quote: > Hi, > > I've just got a new PC running Vista. > > Previously had my "My Documents" running on a network share as I accessed it > from my laptop and my desktop at different times. I also have a backup system > running off the share. > > Now, I've been able to move the location of the Documents folder via the > locations tab to point to the network share. That all worked fine. "My > Documents" appears as a yellow folder in my personalised folder access area > that has my user name. > > Also the "Documents" link on the panel that appears when you click the > "Start" button as it used to be called has changed to be called "My > Documents" and takes me to the network share. > > However, when I reboot the network connection is not reestablished. I have > to go and login to the network share again manually. This is despite the fact > that I keep telling Vista to remember the password. > > Also, when I do go and relogin to this network share there is then a lag > before the My Documents folder reappears in my "home" directory and a further > lag again before the "Documents" link on the start panel changes to "My > Documents". In the meantime clicking on that "Documents" link does nothing. > > What can I do to have everything retore how I want it on start up? > > Thanks |
| My System Specs |
| 11-04-2007 | #3 (permalink) |
| | Re: Problem mapping Documents to network drive That's done the trick. Thanks for your help. "MurphyWong" wrote: Quote: > > Dear Dave, > > Did you try adding EnableLinkedConnections to your Windows registry? > Please see http://www.pctipsbox.com/enabled-lin...ons-for-vista/ > for details. > > HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies > \System > EnableLinkedConnections = 1 (DWord) > > Regards, > Murphy > > > > On 11 4 , 12 31 , DaveW1964 <DaveW1...@xxxxxx> > wrote: Quote: > > Hi, > > > > I've just got a new PC running Vista. > > > > Previously had my "My Documents" running on a network share as I accessed it > > from my laptop and my desktop at different times. I also have a backup system > > running off the share. > > > > Now, I've been able to move the location of the Documents folder via the > > locations tab to point to the network share. That all worked fine. "My > > Documents" appears as a yellow folder in my personalised folder access area > > that has my user name. > > > > Also the "Documents" link on the panel that appears when you click the > > "Start" button as it used to be called has changed to be called "My > > Documents" and takes me to the network share. > > > > However, when I reboot the network connection is not reestablished. I have > > to go and login to the network share again manually. This is despite the fact > > that I keep telling Vista to remember the password. > > > > Also, when I do go and relogin to this network share there is then a lag > > before the My Documents folder reappears in my "home" directory and a further > > lag again before the "Documents" link on the start panel changes to "My > > Documents". In the meantime clicking on that "Documents" link does nothing. > > > > What can I do to have everything retore how I want it on start up? > > > > Thanks > > |
| My System Specs |
| Similar Threads for: Problem mapping Documents to network drive | ||||
| Mapping a network drive | Vista networking & sharing | |||
| Mapping Network Drive With Username & Password | PowerShell | |||
| mapping a drive to an NT4 network shre | Vista networking & sharing | |||
| Mapping Network Drive username | Vista networking & sharing | |||
| Mapping a network drive with different credentials? | Vista networking & sharing | |||
