Vista - Vista speed problem
Old 11-03-2007   #1 (permalink)
CP
Vista speed problem
I have a Dell 6400 with Centrino Duo 1.8Ghz and 1gig of Ram with Vista
preloaded. Eventhough I only have a couple of programs loading at start up
(AVG, Windows Live) it takes about 6 minutes before I can do anything.
My sister has a similar system and hers takes about 15minutes to boot up.
Is changing to XP the only solution?
Old 11-03-2007   #2 (permalink)
Andre Da Costa[ActiveWin]
Re: Vista speed problem
Apart from the two utilities you mentioned, have you checked your Startup
Programs to see if there is a possibility of other unnecessary applications
starting up with the System? Open the run command (Win key + R) type
MSCONFIG > hit Enter > select the Startup (tab), uncheck any unnecessary
applications that might be starting up with the System. Also do a Disk
cleanup (Click Start > type > Disk Cleanup open it > select your drive,
follow instructions to clean out specific locations and temporary system
files.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"CP" <CP@xxxxxx> wrote in message
news:E2FBA52E-78AB-4D62-877D-4CF35E56EEBF@xxxxxx
Old 11-03-2007   #3 (permalink)
Charlie Tame
If you see the drive light flashing at these times try right clicking on
the drive icon and go 'Properties'. Uncheck indexing. See if that helps any.
I assume you follow the proper shutdown procedure so the drives should
be okay, this can sometimes happen when drives get corrupted, but there
are lots of other things too. Try disabling your anti virus / security
programs and see if that make a difference.
Do you both have the same things, is there some common factor?
Old 11-03-2007   #4 (permalink)
Kerry Brown
This might help diagnose the problem.
http://windowshelp.microsoft.com/Win...a33851033.mspx
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
Old 11-03-2007   #5 (permalink)
John
Start by removing as many of the preinstalled 'bloatware' programs you can.
OEMs are notorious about overloading their computers with crap because they
get paid to do so.
Old 11-03-2007   #6 (permalink)
will_s
What I would do is a clean installation of Vista and only vista ie. no
liveware or av program to start with ( actually no liveware ever ).
and see how long it takes to boot up.
Old 11-03-2007   #7 (permalink)
Frank
Alias wrote:
>>> start up
>>> up.
> So you solution is for the OP to buy a new copy of Vista (and need to do
> a hardware driver search) or reload the bloatware that comes with a Dell
> (and probably includes a free trial of Norton or McAfee)?
> My suggestion is much better and much cheaper.
You don't have a real suggestion. You have a loser cause you need to
promote that goes perfectly with the loser you are.
What you really need do is go on over to your chapel, opens sores, and
kiss RS's hairy arse for him.
I bet you're just his type!
Frank
Old 11-03-2007   #8 (permalink)
Charlie Tame
>> start up
Yes, I forgot to add "Turn off Defender"
Old 12-07-2007   #9 (permalink)
grabber
RE: Vista speed problem
i have a Toshiba laptop and the boot time is slow with vista, my desk top
boots with in 30sec xp of coarse. laptop 3min before i can use it. vista
sucks!!!!!!!!
Help Vista problem/ double clock speed Drivers
Problem| Vista isn't showing my actual cpu speed! General Discussion
Problem of speed in vista Vista General
problem w/internet speed w/vista Vista performance & maintenance
Problem with USB speed? Vista hardware & devices
