Vista - USB External Drive Problem
Old 11-04-2007   #1 (permalink)
wf4b
I recently upgraded my computer from a core 2 dual processor to a core 2 Quad. The BIOS
was also updated at that time. I am running Vista Ultimate and everything is working fine
except my external USB hard drive. When I cold boot my computer, the external hard drive
is visible in "My Computer" and it appears in the tray as a device which can be removed.
The device manager also shows it as OK. However when I try to open the drive, it tells me
the folder is empty. If I unplug the device and plug it back in, I get an "unknown
device" error. If I shut the drive off and turn it back on it works fine. I looked in
CMOS but didn't see any parameters that seemed relevant. Any ideas?
1 TB External Hard Drive Problem Vista hardware & devices
Problem with External Drive General Discussion
USB external hard drive problem. Vista hardware & devices
External Drive Problem Vista General
External hard drive problem Vista hardware & devices
