Vista - Help removing Corel paiint shop pro photo x2 TRIAL
Old 11-04-2007   #1 (permalink)
Iceschlie
I loaded this trial version onto my vista 64 computer. When i uninstall or
remove this program ALL of my shortcuts to launch programs do not work
anymore. WOW, Adobe Elements, ventrilo, CCleaner. And when I go into their
folders to launch, there is not program to launch from. So, How did this
trial version get so deep into my computer that is is ruining my already
established programs? After I remove Corel paint and try to launch a
program I get an error that states program is not available. Does this make
any sense. I am losing it. I keep using my restore to get my programs back.
Old 11-05-2007   #2 (permalink)
Charlie42
Re: Help removing Corel paiint shop pro photo x2 TRIAL
Iceschlie <Iceschlie@xxxxxx> wrote:
> uninstall or remove this program ALL of my shortcuts to launch
> programs do not work anymore. WOW, Adobe Elements, ventrilo, CCleaner.
> And when I go into their folders to launch, there is not program to
> launch from. So, How did this trial version get so deep into my
> computer that is is ruining my already established programs?
> After I remove Corel paint and try to launch a program I get an error
> that states program is not available. Does this make any sense. I am
Well, using System Restore seems like the best thing you can do. I can't
say why other programs are uninstalled along with Corel Paint Shop (unless
they came bundled with Paint Shop), that simply should not happen.
If you can restore all your programs to working order, you should then try
Corel's own removal tool to uninstall Paint Shop properly. Download
zapps.exe from:
ftp://ftp.corel.com/pub/PaintShopPro/X/
Charlie42
Old 06-06-2008   #3 (permalink)
tigersquall
http://www.youtube.com/watch?v=_0omb...eature=related
after looking for ages i found this vidio on youtube. I used the
instruction he gave and it worked perfectly
tigersquall
tigersquall's Profile: http://forums.techarena.in/member.php?userid=51148
View this thread: http://forums.techarena.in/showthread.php?t=846007
Help with Vista 64 and Corel Paint Shop Pro 12.5 Software
Burning photos to disc to print at photo shop Vista music pictures video
Removing Pre-Loaded Trial Software Vista General
Adobe Photoshop Elements 5 or Corel Paint Shop Pro XI? Vista music pictures video
Corel Paint Shop Pro X on Vista Beta 2 Vista installation & setup
