| | Recent Items drop-down menu problems My Recent Items button on the Start Menu has an odd problem. Instead of displaying the 15 most recent items, it displays the first 15 items from the Recent folder in alphabetical order. Needless to say, after a few days of use, the Recent Items button becomes useless because it's clogged with items that are alphabetically prior to more recently viewed items. I don't know when this problem started, since I only started trying to use the Recent Items button about a week ago. Anyone know how to fix this? |
| | Re: Recent Items drop-down menu problems I found this in some other newsgroup. It worked for me and also solved the problem that you described. Symptom When you open the Windows Vista Start menu and right-click Recent Items, the option Clear Recent Items List may be missing. Also, the Recent folder may be displayed with a generic folder icon in Windows Explorer. Resolution This happens if the desktop.ini file in the Recent folder is deleted. Thanks & Credits to dean-dean for posting this solution in the Microsoft Newsgroup. * Click Start, type "%AppData%\Microsoft\Windows" and press {ENTER} * Right-click the folder named Recent, and choose Delete. Click Yes when prompted. * Now, type the command "shell:recent" in Start - Search box, and press {ENTER}. Logoff and login back. You should now see the context menu entry Clear Recent Items List when you right-click on the Recent Items folder in the Start menu.. -- Jeroen Posted via http://www.vistaheads.com |
Recent items - mysterious items appearing | General Discussion | |||
| Missing "Recent Items" entry in Start Menu | Vista installation & setup | |||
| How to change Recent Items from Start menu | Vista General | |||
| Recent Items menu problem | Vista General | |||
| Things Missing From Recent Items in the Start Menu | Vista file management | |||
