Vista - Hard drive capacity keeps dropping
Old 11-10-2007   #1 (permalink)
I FLY
i have a new laptop with 250GB HD, after built all all programs were
installed it left me with 192GB. i havent installed any new programs or music
but have noticed it has dropped down now to 174GB, this is very strange, any
suggestions please.
Old 11-10-2007   #2 (permalink)
Re: Hard drive capacity keeps dropping
Quote  Quote: Originally Posted by I FLY View Post
suggestions please.
Hi I FLY,
Here are some common things that can eat up your hard drive space to check.
1. "System Restore" Points Maximum Disk Space Usage.
See: System Restore - disk space
or you can disable System Restore.
See: System Restore
2.The "Vista Temp files" may be building up and need to be cleaned. You can use Disk Cleanup to delete these files.
See: Disk Cleanup
Old 11-10-2007   #3 (permalink)
Annie R J Brion
> suggestions please.
System Restore uses many of GBs of the drives space.
<http://windowshelp.microsoft.com/Windows/en-US/Help/9f6d755a-74bb-4a7d-a625-d762dd8e79e51033.mspx>
I have System Restore switched off and use Acronis TrueImage (System
State backup) to backup to my second HDD. This allows me to take full
control over my system as I can save the System State when I want to and
to were I store the backup.
Annie___ (VM BB L)________________________________
http://find-out-more.brion.me.uk - http://email-me.brion.me.uk
Old 11-10-2007   #4 (permalink)
Tom Ferguson
So, what is the problem, exactly? Is the system sluggish or otherwise
misbehaving? Or is it simply that the HD shows less space available?
From your information, it would seem that there is plenty of available
space on the HD. You do not report anything unusual.
The system will use drive space for various things like e-mail storage,
temporary file space for the internet browser, disk caching, temporary
file space for file downloads and copy/paste operations. So, keep a eye
on it for a while to get a feel for normal operations. However, unless
other symptoms such as sluggishness or system freezes develop, I would
not get concerned.
Tom
MSMVP 1998-2007
"I FLY" <IFLY@xxxxxx> wrote in message
news:C3D19DAB-FDE8-4FEB-AF73-6EA96093BB85@xxxxxx
> music
> strange, any
> suggestions please.
Old 11-10-2007   #5 (permalink)
I FLY
thanks Shawn, i never noticed the more options tab in disk clean up, i did a
clean up on restore points and left the most recent and HD went back up to
206GB. how often does it make restore points? should i leave it turned on or
do u recommend off.
thanks for the help
marco
"brink" wrote:
Quote:
> > music
> > strange, any
> > suggestions please.
> Hi I FLY,
> check.
> See:
> See: System Restore
> 2. The "Vista Temp files" may be building up and need to be cleaned.
> See: Disk Cleanup
> Hope this helps,
> Shawn
> brink
> *There are no dumb questions, just the people that do not ask them.*
> WWW.VISTAX64.COM (\"HTTP://WWW.VISTAX64.COM\")
> *Please post feedback to help others.*
Old 11-10-2007   #6 (permalink)
do u recommend off.
thanks for the help
marco
"brink" wrote:
Hi I FLY,
> check.
> See:
> See: System Restore
> See: Disk Cleanup
> Hope this helps
Marco,
It really depends on if you keep good backups or not. System Restore can be helpful in fixing some problems by restoring the computer back to like it was on one of the restore points. If you have good backups, then you can disable System Restore to save a junk of hard drive space. You should have good backups anyway since System Restore point files will most likely not be up to date with your current computer files. I would say which is more important to you.
Hard drive doesn't have full capacity General Discussion
Hard drive capacity keeps dropping Vista hardware & devices
