| | boot problem,.,..,,.., Hi all, I had to re-install vista 32bit ultimate as I had changed motherboards and now when booting vista I get DISK BOOT FAILURE PLEASE INSERT SYSTEM DISK AND PRESS ENTER I do this and vista boots up fine. I've tried the repair startup option on the vista DVD but it found no fault. I have checked the BIOS settings and all is fine. Can anyone help solve this problem? System specs... 2x500gb Maxtors in RAID 0. Motherboard Asus Crosshair, 4gb Corsiar XMSpro RAM, AMD FX-64 black edition, 2 x Gainward bliss 8800GTX graphics. Thanks -- VRG Scotty www.vistareadygames.com |
| | RE: boot problem,.,..,,.., Try these boot fixes, or go to Repair Vista Options. http://tinyurl.com/3d4x2r Repair Vista Options - Preferred Sequence "VRG Scotty" wrote: Quote: > Hi all, I had to re-install vista 32bit ultimate as I had changed > motherboards and now when booting vista I get DISK BOOT FAILURE PLEASE > INSERT SYSTEM DISK AND PRESS ENTER I do this and vista boots up fine. I've > tried the repair startup option on the vista DVD but it found no fault. > I have checked the BIOS settings and all is fine. > Can anyone help solve this problem? > System specs... > 2x500gb Maxtors in RAID 0. Motherboard Asus Crosshair, 4gb Corsiar XMSpro > RAM, AMD FX-64 black edition, 2 x Gainward bliss 8800GTX graphics. > Thanks > -- > VRG Scotty > > www.vistareadygames.com > > |
| | Re: boot problem,.,..,,.., "uvbogden" <uvbogden@xxxxxx> wrote in message news:1E76A02F-BDFD-4543-A35D-763B975E2F4A@xxxxxx Quote: > Try these boot fixes, or go to Repair Vista Options. > > http://tinyurl.com/3d4x2r > > Repair Vista Options - Preferred Sequence before it will boot, suppose I'll just have to leave the DVD in the drive -- Scotty© |
| | Re: boot problem,.,..,,.., "VRG Scotty" <vrg-scotty@xxxxxx> wrote in message news:eE9hImDJIHA.3848@xxxxxx Quote: > > "uvbogden" <uvbogden@xxxxxx> wrote in message > news:1E76A02F-BDFD-4543-A35D-763B975E2F4A@xxxxxx Quote: >> Try these boot fixes, or go to Repair Vista Options. >> >> http://tinyurl.com/3d4x2r >> >> Repair Vista Options - Preferred Sequence > I've gone through the steps on the links, and still it needs the Vista DVD > before it will boot, suppose I'll just have to leave the DVD in the drive drive had become E: instead of C: that windows was reporting, so I re-installed with no other sata or IDE drives connected and the problem has gone away thanks for all your advice tho, much appreciated. -- VRG Scotty www.vistareadygames.com Register, it's free. New Xbox section added too. |
| A boot problem ? | General Discussion | |||
| Boot Problem With USB | Vista hardware & devices | |||
| boot problem | Vista installation & setup | |||
| Dual Boot Problem - Misplaced Boot Sector | Vista General | |||
| Dual Boot Problem - Misplaced boot sector | Vista General | |||
