| | Inspiron 5150 running with fan at full speed which generates heat! I am running Vista Beta 2 on my Inspiron 5150 3.0 GHZ, 1.256 GB RAM, 60 GB HDD after upgrading from Windows XP PRO. Now as soon as the laptop boots up and I logon, the fan starts running at full speed which makes the laptop very hot and sometimes I have to shutdown the laptop to cool it down. I tried to find the culprit by stopping services but it does not help. Has anyone else faced this problem? Are there any solutions. Otherwise, I am thinking of reverting back to Windows XP Pro. -- Thanks, Rohit |
| | Re: Inspiron 5150 running with fan at full speed which generates heat! The fact that the fan is running at full speed sounds like the computer is hot, not the other way around. Sounds like the system is getting close to it limits. You wrote that you had to shut down the computer sometimes, did it freeze or did you just get worried about the temperature? Monitor the CPU.temp and/or system.temp to see if they get close to/above recomended limits. Try this: control panel-> system and maintenance-> system-> Advanced System Settings-> Advanced-> visual Effects : select "Adjust for best performance" "Rohit Chaphekar" <RohitChaphekar@discussions.microsoft.com> wrote in message news 3A97952-8614-41D3-8160-723212DD209A@microsoft.com...>I am running Vista Beta 2 on my Inspiron 5150 3.0 GHZ, 1.256 GB RAM, 60 GB > HDD after upgrading from Windows XP PRO. > > Now as soon as the laptop boots up and I logon, the fan starts running at > full speed which makes the laptop very hot and sometimes I have to > shutdown > the laptop to cool it down. > > I tried to find the culprit by stopping services but it does not help. > > Has anyone else faced this problem? Are there any solutions. > > Otherwise, I am thinking of reverting back to Windows XP Pro. > > -- > Thanks, > > Rohit |
| | Re: Inspiron 5150 running with fan at full speed which generates h Although I tried that, it does not help. And I shut it down as I was worried about the temp and ultimately burning my leg ![]() The CPU temp is about 71. -- Thanks, Rohit "Flipperaldo" wrote: > The fact that the fan is running at full speed sounds like the computer is > hot, not the other way around. Sounds like the system is getting close to it > limits. > You wrote that you had to shut down the computer sometimes, did it freeze or > did you just get worried about the temperature? > > Monitor the CPU.temp and/or system.temp to see if they get close to/above > recomended limits. > > Try this: control panel-> system and maintenance-> system-> Advanced System > Settings-> Advanced-> visual Effects : select "Adjust for best performance" > > > "Rohit Chaphekar" <RohitChaphekar@discussions.microsoft.com> wrote in > message news 3A97952-8614-41D3-8160-723212DD209A@microsoft.com...> >I am running Vista Beta 2 on my Inspiron 5150 3.0 GHZ, 1.256 GB RAM, 60 GB > > HDD after upgrading from Windows XP PRO. > > > > Now as soon as the laptop boots up and I logon, the fan starts running at > > full speed which makes the laptop very hot and sometimes I have to > > shutdown > > the laptop to cool it down. > > > > I tried to find the culprit by stopping services but it does not help. > > > > Has anyone else faced this problem? Are there any solutions. > > > > Otherwise, I am thinking of reverting back to Windows XP Pro. > > > > -- > > Thanks, > > > > Rohit > |
| | Re: Inspiron 5150 running with fan at full speed which generates heat! Hello, Disable the "Desktop Window Manager Session Manager" service and see if that helps. - JB |
| | Re: Inspiron 5150 running with fan at full speed which generates heat! If the CPU temp is getting high, you should be able to see witch process that is taking the recourses, I'm wondering if the Indexing service may take a lot of recourses the first 24hours or so. Try down clocking the CPU, monitor the temp. If it stays below limits, let the computer work for it self a day or so, to complete its Indexing. Please let us know if you find out something, this is interesting. Hans Kr. Berg "Rohit Chaphekar" <RohitChaphekar@discussions.microsoft.com> wrote in message news 3A97952-8614-41D3-8160-723212DD209A@microsoft.com...>I am running Vista Beta 2 on my Inspiron 5150 3.0 GHZ, 1.256 GB RAM, 60 GB > HDD after upgrading from Windows XP PRO..... |
| | #6 (permalink) |
| | Re: Inspiron 5150 running with fan at full speed which generates heat! The heat issue is a "Common" aspect of Vista. Because of Glass and other visual enhancements, the GPU (Graphics Processing Unit) runs at a higher level than in previous OS'es. Notebooks weren't designed to have such a constant GPU use and can't dissipate the heat. I've had to use manual fan control programs such as Speed Fan to have the fan trigger temp set lower and run the fans at a higher rotational speed. Also Dell notebooks are already quite warm and it's advisable to have a System Tray monitoring app running to watch CPU/Drive sensors. "Flipperaldo" <hkb@hanskb.net> wrote in message news:5C0EBCBE-CD47-43A2-8D3F-B720D0D6D874@microsoft.com... > If the CPU temp is getting high, you should be able to see witch process > that is taking the recourses, I'm wondering if the Indexing service may > take a lot of recourses the first 24hours or so. > Try down clocking the CPU, monitor the temp. If it stays below limits, let > the computer work for it self a day or so, to complete its Indexing. > > Please let us know if you find out something, this is interesting. > > Hans Kr. Berg > > "Rohit Chaphekar" <RohitChaphekar@discussions.microsoft.com> wrote in > message news 3A97952-8614-41D3-8160-723212DD209A@microsoft.com...>>I am running Vista Beta 2 on my Inspiron 5150 3.0 GHZ, 1.256 GB RAM, 60 >>GB >> HDD after upgrading from Windows XP PRO..... > |
| | #7 (permalink) |
| | Re: Inspiron 5150 running with fan at full speed which generates heat! The fact that the graphics card was not originally intended to support Directx 10 and that it is an AGP interface may be causing the card to be running at full capacity trying to keep up to the new Vista GUI. -- Mark Keeping the fun in dysfunctional! "Rohit Chaphekar" <RohitChaphekar@discussions.microsoft.com> wrote in message news 3A97952-8614-41D3-8160-723212DD209A@microsoft.com...>I am running Vista Beta 2 on my Inspiron 5150 3.0 GHZ, 1.256 GB RAM, 60 GB > HDD after upgrading from Windows XP PRO. > > Now as soon as the laptop boots up and I logon, the fan starts running at > full speed which makes the laptop very hot and sometimes I have to > shutdown > the laptop to cool it down. > > I tried to find the culprit by stopping services but it does not help. > > Has anyone else faced this problem? Are there any solutions. > > Otherwise, I am thinking of reverting back to Windows XP Pro. > > -- > Thanks, > > Rohit |
| Full CPU speed | General Discussion | |||
| RE: big problems with running virtual pc under dell inspiron 9400 | Virtual PC | |||
| hardrive spinning at full speed for hours everyday | General Discussion | |||
| Downloading at full speed gives 'lag'. | Vista General | |||
| Dell Inspiron 5150 Wireless 1350 Adapter issue | Vista hardware & devices | |||
