| | os wont load and start i was having loads of problems with my computer, i have vista. i put in 2 new memory cards and that seemed to solve the problem. it was running great for about 2 weeks. then it slowed down to a crawl. i could switch from program to program but it would take a few minutes. then the wait cirlce would just spin. i went to shut down and it started to go through the shutdown process but then just hung there with the shuting down screen on for a long time . so i shut it down. now it wont complete the start up process. if i start it normally it gets tho the microsoft loading bar then stays there, the bar moves but it dosnt load any more, LNG dont work, safe mode dosnt work any ideas of the problem? thanks |
| | Re: os wont load and start Boot from your Windows Vista DVD, select the System Repair Option > on the setup screen, select 'Repair Computer > Select your installation of Windows > select Startup Repair option and follow instructions. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Lisa" <Lisa@xxxxxx> wrote in message news:5CF14A56-7379-436C-892C-017DDAE4F1DE@xxxxxx Quote: >i was having loads of problems with my computer, i have vista. > > i put in 2 new memory cards and that seemed to solve the problem. it was > running great for about 2 weeks. > > then it slowed down to a crawl. i could switch from program to program > but it would take a few minutes. then the wait cirlce would just spin. > i > went to shut down and it started to go through the shutdown process but > then > just hung there with the shuting down screen on for a long time . so i > shut > it down. > > now it wont complete the start up process. if i start it normally it > gets tho the microsoft loading bar then stays there, the bar moves but it > dosnt load any more, > > LNG dont work, safe mode dosnt work > > any ideas of the problem? > > thanks |
| | Re: os wont load and start See Repair Vista Options in the following tutorial. Repair Vista Options - Preferred Sequence "Andre Da Costa[ActiveWin]" wrote: Quote: > Boot from your Windows > Vista DVD, select the System Repair Option > on the setup screen, select > 'Repair Computer > Select your installation of Windows > select Startup > Repair option and follow instructions. > -- > Andre > Blog: http://adacosta.spaces.live.com > My Vista Quickstart Guide: > http://adacosta.spaces.live.com/blog...3DB!9709.entry > "Lisa" <Lisa@xxxxxx> wrote in message > news:5CF14A56-7379-436C-892C-017DDAE4F1DE@xxxxxx Quote: > >i was having loads of problems with my computer, i have vista. > > > > i put in 2 new memory cards and that seemed to solve the problem. it was > > running great for about 2 weeks. > > > > then it slowed down to a crawl. i could switch from program to program > > but it would take a few minutes. then the wait cirlce would just spin. > > i > > went to shut down and it started to go through the shutdown process but > > then > > just hung there with the shuting down screen on for a long time . so i > > shut > > it down. > > > > now it wont complete the start up process. if i start it normally it > > gets tho the microsoft loading bar then stays there, the bar moves but it > > dosnt load any more, > > > > LNG dont work, safe mode dosnt work > > > > any ideas of the problem? > > > > thanks > > |
| Vista wont load | Vista installation & setup | |||
| MS Office programs wont load from "Start Menu" | Vista General | |||
| VIsta The following boot-start or system-start driver(s) failed to load: | Drivers | |||
| Vista Wont start past load screen | Vista installation & setup | |||
| Vista screensaver wont start computer wont sleep either | Vista performance & maintenance | |||
