Vista - Vista Ultimate language(estonian) installing problem
Old 11-13-2007   #1 (permalink)
Kristjan Vilipold
So the thing is that I checked the estonian language pack on the updates page
and then started updating it. Well, at start it downloaded them. After that
Display language Install/uninstall window appeared and it started installing
the update. It reached 1/4 of the process bar till it told that it if
finished. Well, still english. Then i rebooted and tryed again, and again but
still no estonian language.
So how can I get it? I cant download it too because its ultimates feature
and not possible to download from a web.
Old 11-13-2007   #2 (permalink)
Iain
Re: Vista Ultimate language(estonian) installing problem
Go to Control Panel -> Regional and Language Options -> Keyboards and
Languages Tab.
Under Display language section -> Choose a display language, a dropdown
option of your language should appear if installed correctly.
Old 11-13-2007   #3 (permalink)
Kristjan Vilipold
RE: Vista Ultimate language(estonian) installing problem
Nope, didnt help. Its not listed there.
Old 11-13-2007   #4 (permalink)
Iain
You may have an installer problem, then. Try again.
I installed four language packs from site, but was eventually successful
only after third or fourth time. : (
Old 11-13-2007   #5 (permalink)
Andre Da Costa[ActiveWin]
You should be able to restart or continue from where you left off if you are
downloading the language through Windows Update.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"Kristjan Vilipold" <KristjanVilipold@xxxxxx> wrote in
message news:098937F2-B3F2-44F2-A401-6118E6038FB0@xxxxxx
>> page
>> that
>> installing
>> but
Restart problem when installing vista ultimate Vista installation & setup
Problem installing Canon printer in Vista Ultimate 64 bit Vista print fax & scan
Problem re-installing Vista Ultimate OEM after formatting HDD Vista installation & setup
problem installing software in vista ultimate Vista General
Problem installing Xp after deleting Vista Ultimate Vista installation & setup
