Vista - Data Execution Protection problems
Old 11-14-2007   #1 (permalink)
Ric
I recently had to turn off DEP on my Vista PC (see my post in
microsoft.public.pocketpc.activesync for the reason). To turn off DEP I
followed this advice:
http://vistasupport.mvps.org/disable...prevention.htm
Once the problem with Windows Mobile DEvice Center had been resolved, I
turned DEP back on using the same advice as above.
Unfortunately turning it back on with this advice meant that DEP prevented
Internet Explorer from opening!
I tried to use Control Panel/System/Advanced Settings/Performance
Settings/DEP to switch DEP off for IE, but the tab is all greyed out with a
little "No Entry" sign and I cannot select any of the bullet options.
How can I restore DEP settings to defaults?
Old 11-14-2007   #2 (permalink)
Re: Data Execution Protection problems
Quote  Quote: Originally Posted by Ric View Post
John Barnett's Windows Vista Support: Disable Data Execution Prevention (DEP)
Hi Ric,
First try to do a "sfc /scannow" (no quotes) command to see if it will fix this. You can see how to do this in this tutorial.
http://www.vistax64.com/tutorials/66...tem-files.html
If that does not work, then you can do a Repair Install. This tutorial will show you how.
Repair Install For Vista
DEP(Data Execution Prevention) Problems General Discussion
Data Execution Protection - wth? Vista performance & maintenance
Unable to uninstall programs due to Data Execution Protection Vista performance & maintenance
Data Execution Protection is invincible Vista performance & maintenance
DVD Maker and Data Execution Protection (DEP) Vista music pictures video
