Vista - Documents link problems
Old 11-14-2007   #1 (permalink)
kelly
I tried to redirect my documents folder to the D drive. I managed to do this
but I have decided I want to add a folder to the D drive and redirect the
documents folder to that new folder.
I can't do this as the 'documents folder' is D drive and I can't move the D
drive into D:\new folder.
I tried to restore the default location however I get a message "Failed to
build the list of regular subfolders under "D:\MSOCache". Access is denied"
Please help!
Lost "documents" link Vista General
Documents link is broken General Discussion
Start Menu & The Link to Documents Wrong Vista file management
Documents Folder and Link Redirecting Vista file management
Documents link missing from start menu Vista installation & setup
