I need help with this error message.
  1. #1
    RiisPark Guest
    I keep getting this error message when I'm using the DVD Maker from Vista:
    This problem was caused by Indeo® audio software, which was created by Intel
    Corporation.
    Intel Corporation has informed Microsoft that this product is no longer
    needed and can be disabled or uninstalled.
    However, when I go to uninstall this program it is not listed. Any
    suggestions?
  2. #2
    zachd [MSFT] Guest
    Re: I need help with this error message.
    Indeo Audio Codec, file iac25_32.ax . Unregister it and you should be good.
    What third party codec package did you install that registered that on your
    system? It is *not* registered on the system by default. =\
    Speaking for myself only.
    See http://zachd.com/pss/pss.html for some helpful WMP info.
    "RiisPark" <RiisPark@xxxxxx> wrote in message
    news:E399741D-C068-45F8-B543-56B24FD925CB@xxxxxx
    > Intel
    > Corporation.
    > suggestions?
  3. #3
    RiisPark Guest
    RE: I need help with this error message.
    How do I unregister this file?
    > Corporation.
    > suggestions?
  4. #4
    zachd [MSFT] Guest
    open a cmd.exe prompt as an admin
    Easiest way to do that is to type "cmd.exe" into the Start menu's search
    bar, then right-click on cmd.exe when it shows up in the list above and
    choose Run As Administrator
    accept that prompt
    type:
    regsvr32 /u iac25_32.ax
    at that prompt, hit return. That should pop up a dialog and you should be
    done.
    What codec pack did this? I would really really really really like to stop
    them from breaking users. Usually they listen if you ask nicely, and I'm
    perfectly willing to ask nicely. =D
    news:3F6F64F7-D0C5-459C-BF7A-2BB3B0561213@xxxxxx
    >> Vista:
    >> Intel
    >> Corporation.
    >> suggestions?
  5. #5
    RiisPark Guest
    Thanks, I really appreciate this. I was able to unregister it. I'm not sure
    where it came from--perhaps ROXIO.
    > accept that prompt
    > type:
    > done.
    > >> Vista:
    > >> Intel
    > >> Corporation.
    > >> suggestions?
  6. #6
    zachd [MSFT] Guest
    Nah, Roxio wouldn't do this - it's an old Intel codec that got sold to
    Ligos. Only third party codec packs register this as far as I'm aware. You
    *might* find really old software that registers it too, but probably not.
    news:5D098DDA-21F8-425C-8F42-DFD2EE2551E5@xxxxxx
    > sure
    >> accept that prompt
    >> type:
    >> be
    >> done.
    >> stop
    >> rights.
    >> >> Vista:
    >> >> Intel
    >> >> Corporation.
    >> >> longer
    >> >> suggestions?
Unknown Message Header & Pop3 Error Message Michael Santovec Live Mail 8 20 Dec 2009
new message window uploading photos error message Peter Harrison Live Mail 0 02 Apr 2009
Windows Fax and Scan Error Message - The message could not be sent Nathan Goldberg Vista print fax & scan 3 09 Dec 2008
Windows Mail Error Sending a Message - Non-specific Error Message DP4Jesus7 Vista mail 8 09 Apr 2008
Error message when trying to send message thru private localhost q Dave M. Indigo 0 31 May 2006
