Vista - Battery percentage isn't changing
Old 11-17-2007   #1 (permalink)
kirri
My battery has been on 3% all day and saying that the charger is plugged in
but not charging. This was the case when the charger was not plugged in at
all, so I plugged it in but nothing has changed. My laptop always hibernates
at about 10% power, so how can I fix this?
Old 11-17-2007   #2 (permalink)
Alvin Paul L. Azurin (www.azurin.org)
RE: Battery percentage isn't changing
Maybe it is a software problem. Have you tried updating to the latest
software drivers for your notebook?
Hopefully it is not a hardware problem.
PiNoY enPSYCHoLoKoPeDia (http://www.azurin.org/blog)
Executive Housewife (http://www.azurin.org/blag)
Real Estate World(http://www.azurin.org/reworld)
Old 11-17-2007   #3 (permalink)
Andre Da Costa[ActiveWin]
Re: Battery percentage isn't changing
Contact the manufacturer of the laptop if its still under warranty or let
the batteries drain.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"kirri" <kirri@xxxxxx> wrote in message
news:1A83FEBE-53A4-4A62-93E9-B371DB2C7ADF@xxxxxx
> in
> hibernates
Value as % (percentage) .NET General
Battery maximum charge percentage Vista General
Network Usage Percentage PowerShell
Changing Visual Themes on Battery Power Vista performance & maintenance
Changing power plans shown on battery meter Vista performance & maintenance
