Vista - Vista ultimate 64-bit Booting Problem - Reboots at loading screen
Old 11-17-2007   #1 (permalink)
Javi20
Recently I had to change my motherboard, vista was doing ok before, now when
I try to start vista it will go through all the process of booting up until
it gets to the loading screen with the loading green bar on the bottom. It
will stay her for like 2 seconds and then reboots automatically, it does this
for safe mode and normal booting. Already tried Startup Repair but it didn't
change anything. Please Help
Old 11-18-2007   #2 (permalink)
Rick Rogers
Re: Vista ultimate 64-bit Booting Problem - Reboots at loading screen
Was the motherboard a significant change? If so, then you will likely have
to reinstall Vista if the hardware is profoundly different.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Javi20" <Javi20@xxxxxx> wrote in message
news:89D6389C-910A-43DD-A271-0C70F28C067E@xxxxxx
Quote:
> Hi,
> when
> until
> this
> didn't
blue screen, vista not loading, error says stopped loading to prot Vista performance & maintenance
Vista ultimate desktop reboots Vista General
pc freezes and reboots while booting from Vista HP OEM Vista installation & setup
Vista 64 Ultimate reboots while gaming Vista General
vista booting problems after loading software Vista installation & setup
