Vista - System Restore Points without shadow copy - there has got to be a way!!
Old 11-19-2007   #1 (permalink)
Larry
I've considering getting a small notebook with a 48 GB Solid State disk, but
it only comes with Vista Business. With that little HD space, I really
cannot spare 7-8 GB for Shadow Copies. Frankly, I do not need shadow copies
of my regular files, but I do need system restore points (they have saved my
rear-end more than once in XP). I know that I can shrink the space used for
shadow copies, but I would like for whatever space I allocate to be used for
System Restore Points only - not for backup of user files.
Does anyone know of a way to have "XP-like" System Restore Points in Vista
without Shadow Copy of user files?
Thanks,
Larry
Old 11-19-2007   #2 (permalink)
Kerry Brown
Re: System Restore Points without shadow copy - there has got to be a way!!
The answer is to disable System Restore and VSS then use a 3rd party disk
imaging program with an external USB hard drive. AFAIK System Restore in
Vista cannot be made to work the way you want it to.
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
"Larry" <noemail@xxxxxx> wrote in message
news:13k287281o8kq3d@xxxxxx
Quote:
> Hi,
> but it only comes with Vista Business. With that little HD space, I
> really cannot spare 7-8 GB for Shadow Copies. Frankly, I do not need
> shadow copies of my regular files, but I do need system restore points
> (they have saved my rear-end more than once in XP). I know that I can
> shrink the space used for shadow copies, but I would like for whatever
> space I allocate to be used for System Restore Points only - not for
> Thanks,
> Larry
Old 11-19-2007   #3 (permalink)
Larry
>> Vista without Shadow Copy of user files?
"Kerry Brown" <kerry@xxxxxx-tems.c*a*m> wrote in message
news:87E30C30-0156-43CC-B042-2E253F8849DA@xxxxxx
I was afraid that would be the answer... I guess I'll give Ghost a shot.
Thanks,
Larry
Old 11-19-2007   #4 (permalink)
Kerry Brown
make sure you use a Vista compatible version. Older versions of Ghost are
not Vista compatible.
Kerry Brown
news:13k3eat145fci7a@xxxxxx
> Thanks,
> Larry
Old 11-20-2007   #5 (permalink)
Larry
I was afraid that would be the anwer. Nice going Microsoft...
Thanks for your reply (and sorry for the delay...),
Larry
Old 11-21-2007   #6 (permalink)
Kerry Brown
System Restore in Vista works much better than System restore in XP. It is a
much more robust system less prone to corruption. You are trying to run
Vista on quite unusual hardware. Whatever OS you use on that hardware you
will have to make compromises.
Kerry Brown
news:13k7em9ot89vt2c@xxxxxx
> Larry
Old 11-23-2007   #7 (permalink)
jimmuh
Yeah, but, if it's the system I think it is, it's worth the compromises. It
is FAST, yet very small, and with an outstanding screen and keyboard --
especially for a subnotebook.
> Kerry Brown
> > Larry
Old 11-23-2007   #8 (permalink)
Kerry Brown
I like the idea of systems like this. I could use one myself.
Kerry Brown
"jimmuh" <jimmuh@xxxxxx> wrote in message
news:27D23C28-82F1-43E1-AE02-B56BF4AE207A@xxxxxx
> It
>> is a
>> Kerry Brown
>> >>> disk,
>> >>> points
>> >>> can
>> >>> whatever
>> >> disk
>> >> in
>> > Larry
Old 11-23-2007   #9 (permalink)
jimmuh
Another way you might go -- you might just consider doing without System
Restore altogether under Vista. It's not something I'd recommend ordinarily,
but I've been running Vista very heavily on a half dozen systems since RTM,
without once having to resort to System Restore. Heck, even if you do have a
system failure, installing Vista is FAST (compared, say, to WinXP). As long
as you keep your data backed up you should be fine -- unless you make really,
really bad choices about what you install on the system. I use these Vista
systems for testing software, some of it pretty attrocious. And not one time
have I needed SR.
> Larry
Old 11-23-2007   #10 (permalink)
jimmuh
Me, too. But spouse says I have to wait until one of my two notebooks dies.
Hmmm...
> Kerry Brown
> > It
> >> is a
> >> Kerry Brown
> >> >>> disk,
> >> >>> points
> >> >>> can
> >> >>> whatever
> >> >> disk
> >> >> in
> >> > Larry
The Volume Shadow Copy service used by System Restore is not working. - help! Vista General
Volume Shadow Copy (VSS) - System Restore won't start Vista General
System Restore Points without shadow copy - there has got to be a way!! Vista file management
System Restore Points without shadow copy - there has got to be a way!! Vista performance & maintenance
System Restore Shadow Copy Problem Vista performance & maintenance
