Vista Tutorial - sleep problems
Old 11-21-2007   #1 (permalink)
JerryW
Guest
sleep problems
JerIhave ryw
I have the vista progam. When I put it to sleep it awakes again in about 30
sec. When I turn the DSL modem off before I put it to sleep it works just
fine.
Old 11-22-2007   #2 (permalink)
Administrator
Re: sleep problems
Quote  Quote: Originally Posted by JerryW View Post
JerIhave ryw
fine.
Hi Jerry,
You will need to uncheck the "Allow this device to wake the computer" option for your network device. "Step Five" in this tutorial will show you how.
http://www.vistax64.com/tutorials/63...-problems.html
Old 12-21-2007   #3 (permalink)
Jack G
Guest
RE: sleep problems
I had the same problem, and finally figured out the solution. I went to
Windows Update and found an optional update: microsoft-other hardware-HID
Non-User Input Data Filter. Hope this helps.
Jack G
"JerryW" wrote:
Quote:
> JerIhave ryw
> fine.
Sleep problems Vista General
Sleep Problems General Discussion
Problems with Sleep... Vista General
Sleep Problems help ??? Vista General
