Vista Tutorial - Using Dual Monitors - Won't Retain Settings
Old 11-22-2007   #1 (permalink)
JessiRight77
Guest
Hello. I have a Dell XPS M1710 Laptop that I carry back and forth to
work (where I place it in a docking station). A second monitor is
also attached to the docking station.
In "Display Settings," I have chosen to make the second monitor my
primary monitor, and extend the desktop.
PROBLEM: These settings won't save. Every time the screensaver comes
on, or I restart the computer, the settings revert back and I have to
change them again.
Is this a Vista bug, or something I can fix?
Any help would be appreciated... this is frustrating.
Thanks,
Jessi
retaining display settings on dual monitors Vista installation & setup
settings changed - 3 monitors - maximises window across all 3 monitors instead of 1 Vista performance & maintenance
settings changed - 3 monitors - maximises window across all 3 monitors instead of 1 Vista installation & setup
Using Dual Monitors - Won't Retain Settings Vista hardware & devices
Dual Monitors don't keep settings after startup Vista hardware & devices
