| | recycle bin and system restore I seem to have two possibly serious problems: 1. My recycle bin has just disappeared, and 2. I cannot use system restore. I have tried 5 different restore points but after reboot windows will report nothing restored and the process failed. Thanks for your help in advance. |
| | Re: recycle bin and system restore Right-click on the Desktop, click Personalize, and in the left pane, click Change desktop icons. In the Desktop Icon Settings dialog, enable the Recycle Bin checkbox. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "caratuco" <caratuco@xxxxxx> wrote in message news:0FE3815A-9B77-467E-8318-FFB5E10555B9@xxxxxx Quote: >I seem to have two possibly serious problems: > > 1. My recycle bin has just disappeared, and > 2. I cannot use system restore. I have tried 5 different restore points > but > after reboot windows will report nothing restored and the process failed. > > Thanks for your help in advance. |
| | Re: recycle bin and system restore caratuco wrote: Quote: > I seem to have two possibly serious problems: > > 1. My recycle bin has just disappeared, and > 2. I cannot use system restore. I have tried 5 different restore points but > after reboot windows will report nothing restored and the process failed. > > Thanks for your help in advance. How to restore the Recycle bin icon that has been accidentally deleted - http://www.winhelponline.com/articles/141/1/ Hide the "Delete" command from Recycle Bin context menu - Ramesh - http://www.winhelponline.com/articles/142/1/ 2. System Restore - since you told us nothing about your computer and what you are running, pick the link that best suits your situation: MVP Bert Kinney on System Restore - http://bertk.mvps.org/html/vista.html Got Norton? Problems caused by Symantec - http://bertk.mvps.org/html/symantecdoc1.html System Restore - Error Messages in Vista - http://bertk.mvps.org/html/eerrormsgsv.html Missing Restore Points/Shadow Copies in Windows Vista - http://bertk.mvps.org/html/missingrpv.html System Restore forum on AumHa.net - http://aumha.net/viewforum.php?f=54 Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: recycle bin and system restore Hello caratuco, 1. Righclick the display>personalization>change desktop icons, here you can checkmark the recycle bin and it will be back. 2. Did you create a backup before with Backup and Restore Center? Best regards Meinolf Weber Disclaimer: This posting is provided "AS IS" with no warranties, and confers no rights. ** Please do NOT email, only reply to Newsgroups ** HELP us help YOU!!! http://www.dts-l.org/goodpost.htm Quote: > I seem to have two possibly serious problems: > > 1. My recycle bin has just disappeared, and > 2. I cannot use system restore. I have tried 5 different restore > points but > after reboot windows will report nothing restored and the process > failed. > Thanks for your help in advance. > |
| | Re: recycle bin and system restore caratuco wrote: Quote: > I seem to have two possibly serious problems: > > 1. My recycle bin has just disappeared, and > 2. I cannot use system restore. I have tried 5 different restore > points but after reboot windows will report nothing restored and the > process failed. > > Thanks for your help in advance. Maybe the following info will help with the Recycle Bin issue. Right click desktop / Personalize / Change desktop icons (left pane) / Check the box: "Recyle Bin" / Apply / OK More Info: How to restore the Recycle bin icon that has been accidentally deleted: http://www.winhelponline.com/articles/141/1/ How to hide the "Delete" command from Recycle Bin context menu in Windows Vista: http://www.winhelponline.com/articles/142/1/ As for the System Restore issue...sometimes there are conflicts with other software...virus scanners for example. The best bet is to run System Restore from Safe Mode. Using Windows Vista System Restore http://tinyurl.com/2qhd77 http://www.howtogeek.com/howto/windo...ystem-restore/ Windows Vista - Start your computer in safe mode http://tinyurl.com/397vhf http://windowshelp.microsoft.com/Win...904a11033.mspx -- John Inzer MS Picture It! - Digital Image MVP Digital Image Highlights and FAQs http://tinyurl.com/aczzp Notice This is not tech support I am a volunteer Solutions that work for me may not work for you Proceed at your own risk |
| | #6 (permalink) |
| | RE: recycle bin and system restore just go back to xp "caratuco" wrote: Quote: > I seem to have two possibly serious problems: > > 1. My recycle bin has just disappeared, and > 2. I cannot use system restore. I have tried 5 different restore points but > after reboot windows will report nothing restored and the process failed. > > Thanks for your help in advance. |
| Recycle Bin - Restore | Tutorials | |||
| System Restore: do restore points persist after a restore? | Vista General | |||
| Restore Recycle Bin to Desktop | Vista General | |||
| restore emptied recycle bin | Vista General | |||
| system restore not creating system restore everyday | Vista General | |||
