| | laptop problems theres a problem with my laptop i left the battery charging when i went out to the store for apporxamitely and hour or 2 and when i came back and i press the power button it didnt want to work i dont know what happened to it but i kept pressing the power button and it just didnt want to turn on i left it in hibernate when i left idk what to do im thinking about getting a replacement the warranty is still active but i wanted to have another go at fixing it so i was wondering if anyone can help me out here. please and thank you |
| | Re: laptop problems Hi, Remove the battery and try to start it with just the plug in (some will work this way). Does it work now? How about if you replace the battery? -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Juan Donosa" <JuanDonosa@xxxxxx> wrote in message news:971B0F7A-E022-4990-B5F6-73E74CAB62E9@xxxxxx Quote: > theres a problem with my laptop i left the battery charging when i went > out > to the store for apporxamitely and hour or 2 and when i came back and i > press > the power button it didnt want to work i dont know what happened to it but > i > kept pressing the power button and it just didnt want to turn on i left it > in > hibernate when i left idk what to do im thinking about getting a > replacement > the warranty is still active but i wanted to have another go at fixing it > so > i was wondering if anyone can help me out here. > please and thank you |
| | Re: laptop problems well the plug light is on but the battery light aint so that might be it ill try that and if not ill have to go buy another battery thanks for the help "Rick Rogers" wrote: Quote: > Hi, > > Remove the battery and try to start it with just the plug in (some will work > this way). Does it work now? How about if you replace the battery? > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Juan Donosa" <JuanDonosa@xxxxxx> wrote in message > news:971B0F7A-E022-4990-B5F6-73E74CAB62E9@xxxxxx Quote: > > theres a problem with my laptop i left the battery charging when i went > > out > > to the store for apporxamitely and hour or 2 and when i came back and i > > press > > the power button it didnt want to work i dont know what happened to it but > > i > > kept pressing the power button and it just didnt want to turn on i left it > > in > > hibernate when i left idk what to do im thinking about getting a > > replacement > > the warranty is still active but i wanted to have another go at fixing it > > so > > i was wondering if anyone can help me out here. > > please and thank you > |
| | Re: laptop problems 'Juan Donosa' wrote: | theres a problem with my laptop i left the battery charging when i went out | to the store for apporxamitely and hour or 2 and when i came back and i press | the power button it didnt want to work i dont know what happened to it but i | kept pressing the power button and it just didnt want to turn on i left it in | hibernate when i left idk what to do im thinking about getting a replacement | the warranty is still active but i wanted to have another go at fixing it so | i was wondering if anyone can help me out here. | please and thank you _____ And what did costomer support at your laptop manufacturer have to say? That is the place you should start to solve what is clearly a hardware problem (if it can't be solved merely by removing the battery, replacing the battery and booting up again.) Especially since the system is in warranty. Phil Weldon "Juan Donosa" <JuanDonosa@xxxxxx> wrote in message news:971B0F7A-E022-4990-B5F6-73E74CAB62E9@xxxxxx | theres a problem with my laptop i left the battery charging when i went out | to the store for apporxamitely and hour or 2 and when i came back and i press | the power button it didnt want to work i dont know what happened to it but i | kept pressing the power button and it just didnt want to turn on i left it in | hibernate when i left idk what to do im thinking about getting a replacement | the warranty is still active but i wanted to have another go at fixing it so | i was wondering if anyone can help me out here. | please and thank you |
| | Re: laptop problems Definitely take it back for a replacement or warranty repair if it's still under warranty. -- Richard G. Harper [MVP Shell/User] rgharper@xxxxxx * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ * HELP us help YOU ... http://www.dts-l.org/goodpost.htm "Juan Donosa" <JuanDonosa@xxxxxx> wrote in message news:971B0F7A-E022-4990-B5F6-73E74CAB62E9@xxxxxx Quote: > theres a problem with my laptop i left the battery charging when i went > out > to the store for apporxamitely and hour or 2 and when i came back and i > press > the power button it didnt want to work i dont know what happened to it but > i > kept pressing the power button and it just didnt want to turn on i left it > in > hibernate when i left idk what to do im thinking about getting a > replacement > the warranty is still active but i wanted to have another go at fixing it > so > i was wondering if anyone can help me out here. > please and thank you |
| Serious problems with my laptop | General Discussion | |||
| problems connecting pc and laptop | Network & Sharing | |||
| laptop start up problems and problems in general | General Discussion | |||
| IE Problems on a laptop | Browsers & Mail | |||
| laptop problems | Vista hardware & devices | |||
