Vista - how do i restore 3d flip view in my system
Old 11-25-2007   #1 (permalink)
ay
can anyone help me getting back the 3d flip view.i still can access the
window switcher,but when i click that,opened windows icons are only showing
and not the views of it.i even tried by pressing windows logo button plus
tab,but its not coming.please give me a solution for this.
Old 11-25-2007   #2 (permalink)
msnews.microsoft.com
Re: how do i restore 3d flip view in my system
Is Windows Aero enabled still? If not, that would prevent Flip 3D from
working. If you search the Windows Help and Support for
aero
the Troubleshooting link will tell you everything you need to make sure Aero
is working (your selected Theme is Windows Vista, you have the right color
depth, etc.)
"ay" <ay@xxxxxx> wrote in message
news:0D72291B-4930-4F07-9E4C-15E9521A4CDC@xxxxxx
> showing
Old 11-25-2007   #3 (permalink)
Andre Da Costa[ActiveWin]
Please ensure that Windows Aero Glass theme is enabled (right click Desktop
Quote:
> Personalize > Themes > click the 'Themes' list box and select Windows Aero
Glass).
If that does not work, try refreshing your Windows Experience Index:
1. Click Start
2. In the search box, type Performance Information and Tools, hit enter
3. Click the Update my score link
4. Click Continue on the User Account Control dialog
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
> showing
Old 11-25-2007   #4 (permalink)
Quote  Quote: Originally Posted by ay View Post
Hi Ay,
Make sure that you have the color scheme "Windows Aero" selected. This tutorial will show you how.
Color Scheme
You can also do this by the registry if "Windows Aero" is not listed in the available color schemes. This will show you how.
http://www.vistax64.com/tutorials/10...c-version.html
Old 11-26-2007   #5 (permalink)
inkblot
RE: how do i restore 3d flip view in my system
I had the same problem and found that I needed to go into my Nvidia control
panel and change the color settings. I chose the "Less" option in the Color
Quality section of the display settings and that removed the ability to use
the 3d flip. Change this option back to "More" and then going into
"Personalize" by right clicking the desktop and then look in the Windows
color and appearance section. Choose vista aero for the theme and the flip
function should work.
Old 11-28-2007   #6 (permalink)
ay
> aero
> depth, etc.)
> > showing
> thanks 4 d reply.actually i 4gt 2 inform u people dat i gt flip view back.bt it was all accidental.i didnt have 2 go change d settings and all.when i turned on d system again,it came back.but still i went n checked d theme option 2 c windows aero option s der.but in that its given only windows classic and vista.are all the same.
Old 11-28-2007   #7 (permalink)
ay
"Andre Da Costa[ActiveWin]" wrote:
> Glass).
> 1. Click Start
> Andre
> > showing
> thanks 4 d reply.i got flip view back by turning on the system again.but still i tried in theme settings.but i couldnt find windows aero in it.there are only windows classic and vista.are all the same.i also couldnt find performance and tools options in search engine.why is it that.will it cause any problem in the future.
Old 11-28-2007   #8 (permalink)
David
Has it stopped working since optional update ( ati pci filter something)
Check device manager, for yellow triangle on display adapter.
Check for posts re: ati pci update
Good luck if this is your problem...
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore: do restore points persist after a restore? Vista General
system restore not creating system restore everyday Vista General
PowerDesk "Multi-View" equivelent: Is 3D Flip it? Vista General
