Vista - Printing Problems
Old 11-25-2007   #1 (permalink)
snash5761
Printing Problems
I am running Vista Home Premium Ed. I'm using a Epson 1000ICS
Printer/Scanner. I can print anything from the internet, but since ( I'm
suspecting) an update, I can no longer print anything from Windows Vista
itself, such as Word, Excel and even Paint. When I bring up the print queue
it says document is printing but nothing happens. I can still print anything
from online. I suspect the updates may have done it because, before I had no
problem printing anything, from any program before. Any help out there?
Thanks
Printing problems Vista print fax & scan
Re: ie 7 printing problems Vista print fax & scan
Re: still problems with printing in ie7 Vista print fax & scan
Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems Vista installation & setup
