Speed up Winzip program
  1. #1
    Wade Morris Guest
    when I unzip a pogram or or huge files over 1,000 files it takes a while to
    unzip but I use XP it unzips faster. why does it do that. or how can unzip
    (extract) them faster?
  2. #2
    ThePro Guest
    Re: Speed up Winzip program
    "Wade Morris" <WadeMorris@xxxxxx> wrote:
    0142C1EDEC90@xxxxxx...
    > to
    Try 7-zip : http://www.7-zip.org/
    ThePro
  3. #3
    Dzomlija's Avatar
    Resistance is Futile
    South Africa
    Windows Vista x64 Ultimate
    Local Time: 03:32 AM
    south africa
    Quote Originally Posted by Wade Morris View Post
    when I unzip a pogram or or huge files over 1,000 files it takes a while to unzip but I use XP it unzips faster. why does it do that. or how can unzip (extract) them faster?
    Vista built-in ZIP support leaves much to be desired. Here's a better solution:
    WinZip® - The Zip File Utility for Windows - Zip/Unzip, Encrypt/Decrypt
    7-Zip may be free, but it's not the easiest or most user-friendly out there. WinZip may be a better solution for you, even though it's not free.
  4. #4
    Andre Da Costa[ActiveWin] Guest
    Possibly just a limitation of the program. The only thing you can do is use
    an alternative as suggested by ThePro or continue using the built in one in
    Vista or XP since you said you have had good results them.
    Andre
    Blog: http://adacosta.spaces.live.com
    My Vista Quickstart Guide:
    http://adacosta.spaces.live.com/blog...3DB!9709.entry
    "Wade Morris" <WadeMorris@xxxxxx> wrote in message
    news:9BE2E42B-5845-4664-87E5-0142C1EDEC90@xxxxxx
    > to
Solved WinZip Riptorn Software 6 21 Jun 2009
winzip IT Staff PowerShell 5 05 Nov 2008
Solved winzip bassfisher6522 General Discussion 7 20 Aug 2008
winzip file Angelica907 Vista mail 0 21 Jun 2007
WinZip 10 in TaskBar Spanky McFly Vista General 6 21 Jan 2007
