| | Backup Problems This is the issue. 1. I tried backing up my pc using the backup utility. The problem I have is it errored out and now I can't get it to release data. I can delete files but not release the space. 2. Something happened to my media***.bin file that was on the D drive and now is gone. 3. I can't get the computer to restart in a "normal" mode. It keeps restarting in Safe Mode, which I have tried to change by pressing F8. It doesn't work. I keep getting the blue screen!!!! 4. Now... everything has stopped working. I only get errors when restarting. It's all started with the BACKUP!!! Help please. |
| Backup Problems | Vista General | |||
| Backup and Restore problems | Vista performance & maintenance | |||
| Are problems w/backup - common, or just me? | Vista General | |||
| Backup problems w/ Vista | Vista General | |||
| Backup problems | General Discussion | |||
