| | How do I solve a 'Did not load driver' problem? My computer started to hang at startup after removing Norton 360 & replacing it with Avast & Comodo. I tried to do a system restore earlier this morning but the restore failed. On startup, I would usually get one icon in the system tray before the computer hangs. If I right click, the screen is highlighted in a much lighter shade and I get a message asking whether I want to end the process or wait however there is no indication as to what process or application is hanging. Additionally, after I have ended the process a couple of times, after the computer has finished booting super antispyware and my logitech G-series software failed to load properly - I have uninstalled both with no effect. After enabling boot loging, it is stated that 'kbdhid.sys' and 'srv.sys' did not load. The first driver appears to be related to the keyboard which could be why the G15 software didn't load properly. I ran sfc /scannow and it got to 98% file verification before it ended and said it could not fix all files. I ran sfc /scan now in normal mode, not safe mode which I will do shortly. How do I find out exactly what is causing this problem and go about resolving it? Like I said, it only began to happen after removing Norton 360 with the Norton Removal Tool and replacing it with the latest versions of Avast Antivirus and Comodo Firewall Pro. I also installed Google Toolbar after this and I've disabled GoogleToolbarNotifier and Google Updater from loading at startup. In the boot log file. kbdhid.sys is loaded several lines below it's initial failure however srv.sys's failure to load comes right after the log stating that it loaded srv.sys Dave |
| | Re: How do I solve a 'Did not load driver' problem? Turns out it was the Defense+ feature of comodo. As soon as I disabled that computer booted normally. "Dave" <donotreply@xxxxxx> wrote in message news:uGAHsQnMIHA.5860@xxxxxx Quote: > My computer started to hang at startup after removing Norton 360 & > replacing it with Avast & Comodo. I tried to do a system restore earlier > this morning but the restore failed. > On startup, I would usually get one icon in the system tray before the > computer hangs. > > If I right click, the screen is highlighted in a much lighter shade and I > get a message asking whether I want to end the process or wait however > there is no indication as to what process or application is hanging. > > Additionally, after I have ended the process a couple of times, after the > computer has finished booting super antispyware and my logitech G-series > software failed to load properly - I have uninstalled both with no effect. > > After enabling boot loging, it is stated that 'kbdhid.sys' and 'srv.sys' > did not load. The first driver appears to be related to the keyboard which > could be why the G15 software didn't load properly. > > I ran sfc /scannow and it got to 98% file verification before it ended and > said it could not fix all files. I ran sfc /scan now in normal mode, not > safe mode which I will do shortly. > > How do I find out exactly what is causing this problem and go about > resolving it? Like I said, it only began to happen after removing Norton > 360 with the Norton Removal Tool and replacing it with the latest versions > of Avast Antivirus and Comodo Firewall Pro. I also installed Google > Toolbar after this and I've disabled GoogleToolbarNotifier and Google > Updater from loading at startup. > > In the boot log file. kbdhid.sys is loaded several lines below it's > initial failure however srv.sys's failure to load comes right after the > log stating that it loaded srv.sys > > Dave |
| Windows cannot load the device driver for this hardware. The driver may be corrupted | Drivers | |||
| a problem i cant solve | Network & Sharing | |||
| solve the problem with lmpgspl.ax | Vista General | |||
| driver load problem | Vista General | |||
| RE: SPWIZENG.DLL Do you know how solve this problem........... | Vista installation & setup | |||
