Vista - POWER icon missing from Notification area of tray
Old 11-29-2007   #1 (permalink)
Henry
VHP
On a laptop the POWER (battery) icon should always
appear. I can go into Properties -> Notification Area
and check POWER, but the next time the unit is booted
there will be other icons (CLOCK, NETWORK, etc.) but no
POWER...
Old 11-29-2007   #2 (permalink)
Henry
Re: POWER icon missing from Notification area of tray
Huib wrote:
Quote:
> "Henry" <not@xxxxxx> schreef in bericht
> news:fimtrk$gta$1@xxxxxx
Quote:
>> VHP
>> On a laptop the POWER (battery) icon should always appear. I can go
>> into Properties -> Notification Area and check POWER, but the next
>> time the unit is booted there will be other icons (CLOCK, NETWORK,
>> etc.) but no POWER...
> Hi,
> click rightmous on the bottom talskbar, requirements, systemtab and ther
> you will find what hou need.
> regards
> huib
Rightclick on the bottom taskbar does not show
"requirements" or a System tab. I can see TOOLBARS,
ADJUST DATE/TIME, CUSTOMIZE (but there's no help
there!), etc... Properties -> Notification allows me to
start the POWER (battery) indicator, but it must be done
each boot.
Old 11-29-2007   #3 (permalink)
Huib
Quote:
> VHP
> On a laptop the POWER (battery) icon should always appear. I can go into
> Properties -> Notification Area and check POWER, but the next time the
> unit is booted there will be other icons (CLOCK, NETWORK, etc.) but no
> POWER...
click rightmous on the bottom talskbar, requirements, systemtab and ther you
regards
huib
Old 11-29-2007   #4 (permalink)
Huib
news:fin4ab$h46$1@xxxxxx
Quote:
Quote:
>>> VHP
>>> POWER...
>> Hi,
>> regards
>> huib
> Rightclick on the bottom taskbar does not show "requirements" or a System
> tab. I can see TOOLBARS, ADJUST DATE/TIME, CUSTOMIZE (but there's no help
> there!), etc... Properties -> Notification allows me to start the POWER
> (battery) indicator, but it must be done each boot.
Sorry, not "requirements" but "properties" where you can mark in "system"
energie.
I couldn't simulate it but of earlier experience i do know that sometimes
only clicking the ok is not enough ...accept has has to be clicked.
I am using Vista Home Premium.
Regards
Huib
Old 11-30-2007   #5 (permalink)
Huib
Quote:
Quote:
>>> VHP
>>> POWER...
>> Hi,
>> regards
>> huib
energie.
Regards
Huib
Notification Area Icon Vista General
Missing Speaker Icon In Notification Area General Discussion
Power icon no longer appears in notification area Vista installation & setup
Volume, network, and power icon missing from notificaion area Vista performance & maintenance
Network Icon in Notification Area/System Tray Vista General
