| | System Restore does not work I have tried to use Sytem Restore using several different dates and each time I get this response: System Restore did not complete successfully. Your computer system files and settings were not changed. An unspecified error occurred during System Restore. I cannot figure out what the unspecified error is or why System Restore will not restore. Any suggestions. Thanks |
| | Re: System Restore does not work Try running System Restore in Safe Mode, its possible that your Antivirus utility (if you have one installed) is conflicting with it. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "kbc817" <kbc817@xxxxxx> wrote in message news 32CB9C8-E319-46F7-B4D6-703963E64DC0@xxxxxxQuote: >I have tried to use Sytem Restore using several different dates and each >time > I get this response: System Restore did not complete successfully. Your > computer system files and settings were not changed. An unspecified error > occurred during System Restore. I cannot figure out what the unspecified > error is or why System Restore will not restore. Any suggestions. Thanks |
| | Re: System Restore does not work Symantec(Norton) installed by any chance. If it is and most probably that is the culprit that is causing this issue. Get rid of Norton. It causes more headaches and issues with XP\W2003\XP than needed. It is not compatible with most Windows Systems -- Peter Please Reply to Newsgroup for the benefit of others Requests for assistance by email can not and will not be acknowledged. "kbc817" <kbc817@xxxxxx> wrote in message news 32CB9C8-E319-46F7-B4D6-703963E64DC0@xxxxxxQuote: >I have tried to use Sytem Restore using several different dates and each time > I get this response: System Restore did not complete successfully. Your > computer system files and settings were not changed. An unspecified error > occurred during System Restore. I cannot figure out what the unspecified > error is or why System Restore will not restore. Any suggestions. Thanks |
| | Re: System Restore does not work kbc817 wrote: Quote: > I have tried to use Sytem Restore using several different dates and each time > I get this response: System Restore did not complete successfully. Your > computer system files and settings were not changed. An unspecified error > occurred during System Restore. I cannot figure out what the unspecified > error is or why System Restore will not restore. Any suggestions. Thanks -- Regards Arkadiusz 'Black Fox' Artyszuk |
| | Re: System Restore does not work Peter Foldes wrote: Quote: > Symantec(Norton) installed by any chance. If it is and most probably that is the culprit that is causing this issue. Get rid of Norton. It causes more headaches and issues with XP\W2003\XP than needed. It is not compatible with most Windows Systems > |
| | #6 (permalink) |
| | RE: System Restore does not work Thanks for the help. I ran it in Safe Mode and System Restore worked correctly. Only difficulty was getting to Safe Mode; finally just shut down Windows for about 10 seconds when it was operating and when I started it back up, it gave me the option to work in Safe Mode. "kbc817" wrote: Quote: > I have tried to use Sytem Restore using several different dates and each time > I get this response: System Restore did not complete successfully. Your > computer system files and settings were not changed. An unspecified error > occurred during System Restore. I cannot figure out what the unspecified > error is or why System Restore will not restore. Any suggestions. Thanks |
| System Restore doesn't work | Vista General | |||
| System restore and other system apps do not work | Vista General | |||
| Does system restore really work? | Vista General | |||
| System Restore does not work | Vista General | |||
| System Restore Just Doesn't work | Vista performance & maintenance | |||
