| | Driver Problem with Canon LBP2900 Printer Hi Folks, Unfortunately, I encounter a problem with my brand new laser printer Canon LBP2900. It is connected to my computer (Windows Vista) via an USB cable and works properly as long as I am offline. But once I go online, data transfer from the computer to the printer will take several minutes. This phenomenon seems not to depend on the size of the file to be printed. Pages are not printed stepwise (with time interruptions between different pages) but in one single go once printing is initiated. I suspected the firewall (Norton) to be responsible for this delay. But even if I turned it off, delayed printing did persist. I have already uninstalled the printer driver and reinstalled when I was online with no effect on the slowed data transfer to the printer. During data transfer, the program I want to print from (Word, Adobe Acrobat etc.) seems to be pretty busy (task manager will temporarily show 'Not Responding'). When I want to print a PDF, the green status bar will rest at zero percent for ages. Then (after several minutes) it will abruptly turn to 100%. I would be very pleased if somebody could give me some advice here. Thank you so much. Regards Ulf |
| | Re: Driver Problem with Canon LBP2900 Printer Ulf, This group microsoft.public.development.device.drivers is for writing drivers. I would recomend you check the windows vista groups on hardware. You are not likely to get an answer here. -- Don Burn (MVP, Windows DDK) Windows 2k/XP/2k3 Filesystem and Driver Consulting Website: http://www.windrvr.com Blog: http://msmvps.com/blogs/WinDrvr Remove StopSpam to reply <Ulf.Kriemeyer@xxxxxx> wrote in message news:edfa964a-b50e-45b3-ac07-472c331ccc8d@xxxxxx Quote: > Hi Folks, > > Unfortunately, I encounter a problem with my brand new laser printer > Canon LBP2900. It is connected to my computer (Windows Vista) via an > USB cable and works properly as long as I am offline. > But once I go online, data transfer from the computer to the printer > will take several minutes. This phenomenon seems not to depend on the > size of the file to be printed. Pages are not printed stepwise (with > time interruptions between different pages) but in one single go once > printing is initiated. I suspected the firewall (Norton) to be > responsible for this delay. But even if I turned it off, delayed > printing did persist. I have already uninstalled the printer driver > and reinstalled when I was online with no effect on the slowed data > transfer to the printer. During data transfer, the program I want to > print from (Word, Adobe Acrobat etc.) seems to be pretty busy (task > manager will temporarily show 'Not Responding'). When I want to print > a PDF, the green status bar will rest at zero percent for ages. Then > (after several minutes) it will abruptly turn to 100%. > I would be very pleased if somebody could give me some advice here. > Thank you so much. > > Regards > Ulf |
| Canon MP480 printer driver won't install | Drivers | |||
| Vista 64bit Printer driver for Canon Laser Jet LBP-1120 | Vista General | |||
| Driver Problem with Canon LBP2900 Printer | Vista hardware & devices | |||
| driver for canon printer | Vista hardware & devices | |||
| I need the driver for Printer Canon LBP-1210 | Vista hardware & devices | |||
