Vista Tutorial - sound controler software vista 64 & MB temp control
Old 12-03-2007   #1 (permalink)
maxvista
Guest
1, Since vista does not offer the option like previous OS to control sound
individually to front, back, central & subwoofer speakers when using 5.1, 6.1
or 7.1.
my problem is since front & rear are default to same level cannot here the
rear ones defeating the purpose of a surround system.
Anyone familiar with a working software usable on vista 64?
2, i used to like the temperature monitor controler software that came with
my intel motherboard under XP!! very handy and avoids frying your MB parts.
Any software vista 64bit compatible?
Thanks for all the help with previous questions.
Windows Vista strange settings on temp folder AppData\Local\Temp\1 Vista security
Temp monitoring software Software
Vista on server 2000 (domain controler) Vista networking & sharing
IDE ATA/ATAPI controler included in Vista and Harddrive in HP Vista hardware & devices
Is PC Tattletale (keylogger) part of vista parental control software? Vista General
